Archive
This is my first error that I got from MWS and I am stuck with it. I cannot solve it, I can’t get rid of it, I can’t do nothing because of this error. Is anyone available to help fixing this error? Also please tell me how can I prevent this in the future and what is causing it?
Thanks!
MWS Play O.94f
Access violation at address 70D375A4 in module ‘gdplus.dll’ address 00000048.
OK
Read more
Hi there,
Device driver software was not successfully installed – this is the message that I have every time when I connect a new device to my PC. I tried everything, even I reinstalled my Windows Vista and still this error gives me a headache. Please anyone help me to fix this! Why is impossible to solve this?
Thank you very much!
Driver Software Installation
Please consult with your device manufacturer for assistance getting this device installed,
USB Composite Device Ready to use
JamLab Failed
Close
Read more
Hello experts,
This Onekey Theater is causing me lots of errors, this is one of them. I can listen music, watching movies, play games with sound. My sound is working perfect. This is the only software that have problems with my sound card. How can I solve this error? Why this software have compatibility issue with my sound?
Thanks!
Onekey Theater
Please install the correct audio driver before using Onekey Theater.
OK
Read more
I installed the new software for me Video Capture and I have this error when I want to run it. I don’t know why is saying that my sound card is not installed since I can listen music and it works just fine. If I press Yes nothing is happening and the software is closing. Can anyone help me please to solve this error? Is something wrong with my sound card?
Thank you!
Video Download Capture
Virtual sound card can’t be detected, install it now? Otherwise the program cannot run normally.
Yes No
Read more
This morning I had this error from GameRanger and now the program is not opening anymore. I rebooted my PC, reinstall the program and is not working. I have installed the last version, my PC is up to date and nothing seems to work. Can anyone help me to fix this error ? What could cause this one ?
Thanks !
GameRanger Error
GameRanger has encountered an unexpected error and must quit.
This error has been logged automatically.
OK
Read more
I downloaded the latest version for my audio hardware and I have this error. I don’t know why is saying that I need the latest version since this is the only one that I found it. Can anyone help me to fix this? You know any other ways to download the latest version of drivers?
Thank you!
Dolby Advanced Audio
The current Dolby audio driver version is 7.2.8000.17 and the software application expects driver version 7.2.7000.7. Please install a valid driver and software application combination.
OK
Read more
Hi there,
I have this error when I want to install Team Speak 3 on my laptop and I downloaded the version compatible with Windows 7. I tried to download it from different servers and the same problem is everywhere. Please help me to solve this! Why I have this error? Is something wrong with the software or with my laptop?
Thanks!
ts3client_win64.exe - Bad Image
C:Windowssystem32HID.DLL is either not designed to run on Windows or it contains an error. Try installing the program again using the original installation media or contact your system administrator or the software vendor for...
Read more
Hi experts,
I have this error with MediaMonkey and I can’t solve it. Is this access violation and I don’t that blurred me totally. I can’t find this module_iPhone.dll on the Internet so I can copy it manually. How can I solve this error? Is ok if I run a DLL fixer on my laptop? It will solve something or will get the things worse?
Thank you!
Exception EAccessViolation in module d_iPhone.dll at 6A33AB69.
Access violation at address 6A33B869. Read of address 6A338B69.
OK
Read more
Today I tried to sync my Nokia phone with my PC and suddenly this error appeared on my desktop. I am afraid now to connect my phone to my PC because I think I can get some of these errors in my phone and I want to avoid this problem. Please help with this error and tell me if is possible that I have errors in my phone?
Thank you!
Qt Creator - Plugin loader messages
C:Qtqtcreator-1.383libqtcreatorpluginsNokiaHelp.dll: Cannot load library
C:/Qt/qtcreator-1.3.83/libfqtcreator/pluginsfNokia/Help.dll: Das angegebene
Modul wurde nicht gefunden.
Cannot load plugin because dependency failed to load: Help(13.83) Reason: C:Qtqtcreator-1.3.83libqtcreatorpluginsNokiaHelp.dll: Cannot load library ClQtfqtcreator-13.8311ib/qtcreator/pluginsfNokialHelp.dlI:...
Read more
Hi there,
I have this error with DirectX and I cannot solve it. My researches on the Internet have zero results and I can’t get rid of it. Does anyone have any idea how can this error be solved? I did something wrong in my PC?
Thank you!
Microsoft Visual C# 2010 Express
A reference to ‘C:Program Files (x86)Microsoft DirectX SDK (June
- 2010)Developer Runtimex64d3dref9.dll could not be added. Please make sure that the file is accessible, and that it is a valid assembly or COM component.
Read more
