Archive
After uninstalling some softwares and games from my PC, when I want to install new ones that I really need I get very often this kind of errors. Missing DLL files is the most common error that I have and I don’t know how I can solve this. Does anyone can help me with this error? Is there any way to get back the missing DLL files?
Thank you!
Compass 2.0 Windows Downloader
76
File not found: ..DLLInstallationUtil.dIl
Read more
Hi there,
Recently I bought this HP 3D Drive Guard and I have some problems installing the driver. At that moment it wasn’t really necessary to me so I skipped the install. Now I need and this version of driver I guess is not good. I can’t find an update or any advices about how can this error be solved. Please tell how can I do this? Is any update available and please tell from where it can be downloaded?
Thanks!
HP 3D DriveGuard
The HP 3D DriveGuard driver cannot install, the Accelerometer hardware is not present...
Read moreHi,
I have this error when I want to open my HP configuration. It’s saying that this app is already running and I should close it first. I opened my Task Manager in Processes tab and is not running, but I have this error every time. Can you help me to fix this error? What should I do to prevent this?
Array Configuration Utility 7.60.18.0
Only one instance o the Array Configuration Utility can be running.
The Array Configuration Utility is already running as an application on this server.
In order to perform this operation, you must first...
Read moreHi there,
I made the necessary updates for Joost and now I cannot use the program. I don’t know why it says that my network connection is not working since I can surf over the Internet. Please help me to fix Joost Player and tell me what is the problem with it.
Thank you !
An error occurred!
Unable to connect to the network
Please visit www.joost.com for more information or email [email protected]
Read moreHi there,
I have this Error 4014 on my iPhone 4 and after a long researches on the Internet no answer was found. I even spoke with the iTunes Support and they said I will get an answer ASAP. It passed almost two weeks since then and I still have the error. Does anyone know what this error means? Please help me to pass this…
Thank you experts!
Fixing iTunes Error 4014.
Read moreHi there,
This error appeared in Apache Cordova when I have connected my android phone to my PC. I never had this kind of error before and everything worked fine. Now I am stuck with error and please is there an expert online that can help me with this ? Is something wrong with my phone ?
Thanks !
Apache Cordova
Connecting to Device
Device is Ready
Alert
[ERROR] Error initializing Cordova: Class not found
OK
Read moreHello,
Sibelius 7 have this error when I want to activate the license. I have bought the program with a license and it seems like I cannot activate it. Can anyone help me to fix this ? What could be the problem that doesn’t let me to activate the program ?
Thank you !
Sibelius 7
There was an error initializing the licensing engine. This often happens if you have migrated data from another computer. Please delete the following folder, then restart Sibelius 7: /Library/Application Support/Avid/Licenses/Sibelius.
OK
Read moreHi experts,
I have this screen with this message after I fail every time when I want to activate my game FABLE III. I have the original game with an original key and all the time it says that the activation key is not on their database. The key is not working even if I activate the game manually. Can anyone help me please to activate my game? Is there a possibility that the game store cheated me? Thanks!
Fable III – Activation Failed
Activation process has been terminated
The Activation Key was not found in the database. Most...
Read moreHello,
My PC can’t connect to the EA servers when I want to activate my game FIFA Soccer 13. With my account I can connect from another PC to EA Servers but I need to activate the game from my PC. Does anyone have any idea about this message ? Is there a problem with my internet connection ?
Thanks !
FIFA Soccer 13
Error
We’re sorry, an error has occurred
We are unable to connect to EA servers to activate FIFA Soccer 13 on this computer using your account. Please try again later.
Exit
Read moreHello there,
I have this program from a friend and after install this error appears when I want to open it. On my friend PC the programs works just fine and on my PC a license is required. I have asked my friend about this error and he couldn’t help me. Can any of you experts help me ?
Thank you !
Cube Text Editor
Cube must be installed and licensed for this application to run
OK
Read more
