Archive
After I have uninstall my antivirus and after reboot this error message appeared on my desktop after 5 minutes. I click OK and nothing happened, but it appeared again after another reboot. I don’t know how to fix it and please can anyone help me with this error? What is the problem with my PC?
Thanks!
exeaPickITTool
Fatale fout: Unable to load DLL ‘rapi.dll’: The specified module could not be Found. (Exception From HRESULT: 0x8007007E)
OK
Read more
Hello there,
After installing my webcam and try to run it this error with DLL appeared. I have reinstalled the program several times and again this error. Anyone have any idea what is with this error? How can I solve it and why it doesn’t work after I did everything that the error says?
Thank you!
Cannot find import DLL may be missing, corrupt or wrong version File “dd10shrd.dIl’, function
“?setElementDisplay@CIsHtmICtrl@@IAEXPBDHH©Z’ (error 0)
OK
Read more
Hi there,
I uninstalled a program and after I reboot my PC this RunDLL error appeared. This error appears every time I open my PC. After some searches on the Internet I didn’t find anything. I would like to know if I install the program again this error will disappear. How can I fix?
Thank you!
RunDLL
There was a problem starting
C:UsersIBNUPR~1AppDataLocalTemp\tsiVi032.dll
The specified module could not be found.
OK
Read more
Hi there,
After installing ArchiCAD this error stopped me to work with this program. I did a small research on the internet about this error and nothing useful was found. Please help me to fix this error. I really need to make a project to school.
Thanks experts!
ArchiCAD.exe. System Error
The program can’t start because GSQuickTime.dll is missing from your
computer. Try reinstalling the program to fix this problem.
OK
The program can’t start because GSRoot.dll is missing from your
OK
Read more
When I try to log in to SQL server I have this 28000 error message. Also, recently I have made an update to my MAC and I think that’s may be the problem. I never experienced such problem before and I am a bit confused. Anyone here can help me with this error and tell me how can I solve it?
Thanks!
Microsoft SQL Server Management Studio
Error loading type library/DLL.
OK
Read more
This run-time error appeared when I turned on my PC. Is not my first DLL error and I think I solved once and for all the DLL errors with DLL fixer. I think is not working as I expected but can anyone help me to fix one? Why I have DLL errors? Can this be solved forever?
Thank you!
Bad DLL Call
ERROR: Function call has invalid parameter (step number 3, max=2)
OK
Read more
I have a Dell laptop with 6GB RAM, CPU I5 3.2GHz and 500HDD. I got this error this morning on my Windows XP and I don’t know what it means. I have 6GB RAM I don’t know why it says that I don’t have virtual memory. Does anyone know why I have this error and how can I fix it?
Thank you!
SearchFilterHost.exe - Application Error
The instruction at “0x0350622a” referenced memory at “0x00000014”. The memory could not...
Read more
Hi experts,
I have installed a new online game on my laptop and I when I want to log in this Client error appear and close my game. On my laptop I have another 2 online games and they are running smoothly. Why I can’t log in on my Client? Is this game with error or my PC?
Thanks!
Client.exe - Entry Point Not Found
The procedure entry point av_asprintf could not be Located in the
 dynamic link Library avutil-51.dll
OK
Read more
During the install of a small program this error appeared and stopped the process. I tried to install software and the same error appeared. It seems like most of my software can’t run on my PC because I have this kind of error appear to all. How can I solve this error? Please tell me why I have this kind of errors?
Thank you!
The InstallSheild Engine (iKernel.exe) could not be installed.
The system cannot find the file specified.
Read more
I can’t run AsusSetup on my Windows XP (x32) because of this error. It seems like is a compatibility error. I run the same version and a compatible one with Windows XP and it doesn’t want to work either. Please can anyone help me to fix this? Why is a compatibility error?
Thanks!
AsusSetup
Does not support this Operating System : WNT_6. 1P_64_MCE
OK
Read more
