Archive
Hi there,
Checking on official OCQ website to see if it is available in my country I found out that it is. But, I still have this compatibility issue when I want to install the program. I have downloaded the latest version for download and it doesn’t work. Does anyone have any idea about this ? Why I can’t install the program even is available for use in my country ?
Thanks !
ICQ
This ICQ version is not available for use in this country.
Would you like to download the latest available version from www.icq.com?
Yes No
Read moreHi,
This morning I got this message when I tried log in to ICQ. I have been waited for all day hoping that I will log in to ICQ. I did a small research over the Internet and it seems like is a common error without a good solution. Can you experts help me to fix this error ? What could be the main error and what is causing it ?
Thank you !
ICQ Error
Unable to connect to ICQ login server, SSL could not be negotiated
Warning
SSL connection failure (80090308 473): Client cannot decode host message. Possible causes:...
Read moreHi there,
This is an unknown error for me. I have no idea what causing it, from where did it came from and why. All I know that it appeared suddenly on my desktop. Anyone can recognize this error? What is causing it?
Thank you!
MICSTO
Could not implement all needed function hooks.
OK
Read more
I tried to update my Internet Explorer and it fails. I reinstalled the old version 7 and now I have this error. My PC is full with error because I had a lot lately. Now I can’t use my browser and I really need access to the Internet. Does anyone have any idea what is the solution for my error? It is possible please help me to make the update…
Thanks!
The ordinal 379 could not be located in the dynamic link library iertutil.dll.
OK
Read more
I can’t install McAfee Agent because of this error 1722. It seems like the installer package have errors so looked up to download from another servers. Always I have the same error 1722. Can anyone help me to install McAfee? What could be the problem?
Thanks!
McAfee Agent
Error 1722 .There is a problem with this Windows
Installer package. A program run as part of the setup did not finish as expected. Contact your support personnel or package vendor. Action RegisterNaPrdMgr, location: C:Program FiIesMcAfeeCommon FrameworknaPrdMgr.exe,
command: RegServer
OK
Read moreHi there,
I uninstalled a program and after I reboot my PC this RunDLL error appeared. This error appears every time I open my PC. After some searches on the Internet I didn’t find anything. I would like to know if I install the program again this error will disappear. How can I fix?
Thank you!
Error loading C:Program FilesCommon FilesParetoLogicUUS2UUS.dll
The specified module could not be found.
OK
Read moreHello,
This GIF Animator started lately to give me lots of error. I solved most of them after I spent a lot of time in reading, searching and kill my nerves. I give up with this one. Can you Techyv help me to fix this error?
Thank you!
Ulead GIF Animator
Unable to add the image Filter effects.
Failed to load the specified plug-in.
[2401:2401:408] OK
Read moreHi there,
Thank you!
RunDLL
Error loading C:Windowssystem32gameux.dll
Read moreI have installed this program because I need to cut some mp3 to create a story. Can anyone help me to skip this error so can I continue creating a beautiful story for my children? If know any other software that might help me I am open to any recommendations!
Thank you experts!
Mpg2Cut2
MPA_SSE1.dll - NOT LOADED
Load: rc=x6969
*** Need BOTH LibMMD.DLL andMPA_SSE1.dll ***
to be copied into Windows System folder or Dos PATH.
Read moreHi,
I installed Yahoo Messenger because I need to keep in touch with some foreign students. It seems like Yahoo Messenger have a lot of users especially people from Eastern Europe. I can’t start to use this program because of this error. Does anyone have any idea on how can this be solved?
Regards!
The program can’t start because nspr4.dll s missing from your computer. Try re-installing the program to fix this problem.
OK
Read more
