Archive
Hi there,
This Connection Error appears when I want to connect to the Internet. I did a fresh install and is not working at all. I don’t know why it says that I don’t have a password set to my host because I have one. Can anyone help me to fix this error of my app? Thank you!
Connection Error
Your credentials are correct, but Windows does not allow empty passwords for RDP access. Please set a password for your user on the host.
Support Website OK
Read more
On my desktop this error appears every time I open my PC and I have to click OK so I can continue to use it. I don’t remember to change anything in the system that might cause this. Can anyone help me to fix this problem? What is causing this? Thanks!
Problem occurred
‘Cloning from git+ssh://[email protected]/gitroot/marketplace/org.eclipse.marketplace.git’ has encountered a problem.
Ssh://[email protected]:22:Password:
OK <<details
</details
Read more
When I wanted to run a game this morning this error message close the game and left my screen black. Is for the first time when a game gives me an error and block my MAC. I have checked the settings of my video card and is working properly. Someone please help me to fix this and tell me why I have this error ?
Thank you !
The application Football Manager 2012 v 12.0.1f225816 quit unexpectedly.
Mac OS X and other application are not affected.
Click Relaunch to launch the application again. Click Report to see more...
Read more
Hi there,
I have a new Mac for two days and today for the first time this error appeared on my desktop after the startup finished to load. Is my first Mac and I am lost with this error. Please experts help me to fix this !
Why I have this error and is a system error or a user error ?
Thanks !
Unable to mount 80 GB Filesystem
Error mounting: mount exited with exit code 1:helper failed with: mount:only root can mount/dev/sda7on/media/80GB
OK
Read more
Hi there,
I have this error when I want to connect to my Internet VIA Dial up. I’ve made the connection as the book said and it doesn’t want to work. All the time I have the same error and I don’t know why. The Internet connection is good because I’ve called and they said to that is active. Can anyone help me please to make a new connection ? Why the connection by the book doesn’t work ?
Thank you experts !
Error Connecting to VPN Connection Indonesia
Registering your computer on the network…
Error 734: The PPP link...
Read more
I want to transfer some files from my laptop with Linux to my PC with Windows 7 using LAN. This error appears and says that cannot mount volume. I don’t know what it means and I can’t copy the files using USB because is a large volume data. Any advice ? How can I make LAN connection between this two ?
Thanks !
Cannot mount volume.
Invalid mount option when attempting to mount the volume ‘inScope’.
OK
Read more
During the game this error message box appeared and closed my game and I lost some data because I didn’t save them. Sometimes this error appears and sometimes it didn’t. Can anyone help me please so fix this error? What is causing this and how can I prevent it in the future? Thank you!
Application Error
A serious error was encountered and the application will close. An error file has been generated in:
C:UsersJonDocumentsSports InteractiveFootball Manager 2012crash dumpsFM 2012 v12.0.4.233639 (2011.11.2520.28.30).dmp
OK
Read more
Hi experts,
S.T.A.L.K.E.R Prequel: Clear Sky Error gives me this error when I want to play the game. I have inserted the CD with the game and still it asks for a CD. Does anyone have some free time to help me to fix this so I can play this game please ?
Thanks !
Insert the ?.?.?.?.?.?.?.?: ???????? ???? disc into the disc drive and press “retry”. If the disc is in the drive make sure its contents can be viewed in the Windows Explorer. If it is a multidisc product, try the...
Read more
Hi there,
I have kind of error when I try to use my Internet browser and I have to quit. Nothing seems to work now on my PC because I tried 4 different browsers. Does anyone have a solution for this error ? What is causing this error ?
Thanks !
Attention
Error: We have encountered an error, which we will investigate immediately. Sorry for the inconvenience. Error code: 2n36b1.
Read more
Hi there,
I am using Kdenlive 0.92 with Fedora 17 KDE and the from all option only on is available: DV PAL 16:9 and the rest are unavailable and I can’t use them. I heard that this is the best video program and it might help me a lot. Can anyone help me to fix this ? It might be a possible the my VGA is not so good ?
Thank you !
Unsupported audio codec: pcm_s16le
Close
Read more
