Archive
Hello all,
Friends, I am a facing an odd error message when I try to view a word document in the office web apps. The error message indicates that it cannot open the document. If this happens, again try opening the document in Microsoft word. I tried to open it several times but I am not able to open it in Web apps. Please guide me to open it using Web apps. Your help is appreciated. Thank you.
Microsoft Word Web App
Sorry, there was a problem and we can’t open this document
Read moreHi all,
When I try to install the Microsoft office Professional Plus 2013 trial package in the computer I ended up with an error message. I do not understand where I went wrong I do enter the correct product key. I uninstalled the previous version of Microsoft Office 2013 in the computer. Still I am getting this error message, how do I fix the problem? Please help.
Microsoft Office Professional Plus 2013 Trial
Office
Microsoft Office...
Read moreHello,
I am facing a weird error message while I try to create a new account in Microsoft Outlook. To my knowledge, there is only one account right now in the computer. I am not a technical person to think out of box, please help me to fix the error and help me to sync my new account with Microsoft outlook. Your help is great. Thanks.
Microsoft Outlook
There are too many devices syncing with this account. To sync using Outlook,...
Read moreHi,
When I try to install Microsoft Office in the computer I ended up with an error message. I have Microsoft office professional plus 2010 and Microsoft office 32-bit components 2010 in the computer. I do not understand where I went wrong. Experts please suggest me an alternate solution. Your help is great. Thanks.
We found a problem!
We’re sorry, Office (32-bit) couldn’t be installed because you have these 64-bit Office programs installed on your computer:
Read more
Nikon 400mm f2.8 lens whats the cost? is it available in US & India?
Where can i buy it and what are the features?
How different is it from the previous version?
Read moreWhat are the latest additions in iPHONE 6
When is it going to be available in the market to purchase?
Any images and tips would help my exitement
Read moreHello,
Appraise-It gives me this access violation error. Yesterday it worked just fine and is for the first time when I have any error with. Does anyone have any solution for this access violation error ? I did something wrong and what happened ?
Thanks !
Appraise-It
Access violation at address 005A04A2 in module ‘TRA.EXE’. Read of address 000000268.
OK
Read moreHello,
From this morning when I have opened my laptop I have this error when I try to open any program. I restarted my laptop hoping that will solve the problem, but it didn’t. I did a system restore and it doesn’t work. Now I can’t use my laptop at all because of this error. Does anyone know if this might be a virus? How can this be solved and what caused it?
Thank you experts!
SETUP.EXE – Application Error
The application was unable to start correctly (0x00000f). Click OK to close the application.
OK
Read moreHello,
On startup of my Windows XP this error message appeared. If I click OK my taskbar is not loading and my screen freezes. After a reset this error appears again, when I click Cancel everything works just fine. I want to get rid of this error but I don’t know how. Please, is there anyone who can help me fixing this error? What is causing this application error?
Thank you!
Inventor.exe - Application Error
The application failed to initialize properly (0x0000142). Click on OK to terminate the application.
OK
Read more
