Archive
Hi Troubleshooter,
After the system update when I try to access the folder in the network, I got this error message. The error message says, “You might not have permission to use this network resource. Contact the administrator of this server to find out if you have access permission. The specified network name is no longer available. Please help me to resolve this network problem.
Open Folder
\isannovklshare is not accessible. You might not have permission to use this network resource. Contact the administrator of this server to find out if you have access permissions.
The...
Read more
Hello all,
The problem triggered when I try to install the AnyConnnect Secure Mobility Client and then receive the error message, "The VPN client was unable to setup IP filtering. A VPN connection will not be established." I have attached the error image please do help me to fix the problem. I tried several times but nothing happened. Do I need to configure or change the settings? Please help. Thanks.
Cisco AnyConnect
Read more
Hi all,
I know this is the common problem with Viper Anti-virus software but I need a help to fix this problem. I got this error message right after the installation when I try to scan the system. I have attached the error image please do look at it and help me to solve the problem. Your help is great. Thanks a lot.
Viper Error
The server address appears to be invalid.
Please ensure the value of the ‘Server’ textbox is set to:
‘net.tcp://gateway.scanmyessay.com:9066/viperlb’ and try again.
Read more
I got this weird error message while I am performing an operation on enterprise vault server, unable to expand EVAnon virtual directory in IIS Manager. It shows error “There was an error while performing this operation” I think I made something wrong while configuration with IP address and Domain restrictions with Enterprise Vault virtual directory. Please help me to fix the problem. Thanks in advance.
IP Address and Domain Restrictions
There was an error while performing this operation.
Details:
Filename: \?C:Program File (x86)Enterprise
VaultWebAppweb.config
Line number: 44
Error: cannot add duplicate collection entry or type ‘add’ with combined key attributes...
Read more
When I try to upgrade the Adobe Flash Player to latest version, I stuck up with an error message. The error message says that Flash version WIN 12, 0,0,44 found. Required version is 10, 1 or above. The version upgraded is above the required version but still I get this error message. How do I fix this problem? Please help. Thanks.
Smarlaunch Client
Flash version WIN 12,0,0,44 found. Required version is 10, 1 or above.
Read more
Hi tech people,
After successful installation of Adobe Flash Player in the windows operating system when I try to start the application for the first time I ended up with an error message. The error message states that it Faiil to generate initiate Flash Player, please try again. Please guide me. Thanks in advance.
Ge
Faiil to generate initiate Flash Player, please try again. (62)
Read more
Hello tech experts,
I get this error message whenever I try to work with the project in the network. I am a beginner so really having hard time with this application. Please help me to change the settings in the application and help me to connect with the internet. Is the reinstallation will help me? Your help is great. Thanks.
Adobe Flash Player Security
Adobe Flash Player has stopped a potentially unsafe operation.
The following local application on your computer or network
Swf url
Is trying to communicate with this Internet-enabled location:
Domain
To let this application communicate with the Internet,...
Read more
Hello there,
Recently I upgraded my system to latest version and it went pretty well and good without any problem. The problem triggered when I try to save an Adobe PDF document from the website. For your information, I have Adobe Reader too in the system and that too updated. I do not understand why I got this error message. Is anything terrible wrong? Please help. Thanks.
Add-ons may be causing problems
Firefox has determined that the following add-ons are known to cause stability or security problems.
Adobe acrobat NPAPI Plug-in, Version 10.1.3   10.1.3
Read more
I just installed Windows Vista on my PC and after the install of Notepad++ I had this error and I don’t know how to solve it. On my previous Windows 7 the Notepad++ worked just fine and I never had any error. Can anyone help me please to fix this error ? What is causing it ?
Thanks !
SetWindowsHookEx(KEYBOARD)faile…
GetLastError() returned 1428
OK
Read more
After I have created an active and available group and it was populated and properly configured with Mailbox server members this error appeared. Any solution for this error ? How can I solve this please ?
Thank you !
Completion
The wizard could not complete. Click Finish to close this wizard.
Elapsed time: 00:00:07
Summary: 2 item(s), 0 succeeded, 2 failed.
Error:
You must provide a value for this properly.
Click here for help…
Exchange Management Shell command attempted:
Add-DatabaseAvailabilityGroupServer-Mailbox.Server ‘VEX01’-Identify ‘DAG01’
Elapsed Time: 00:00:04
Error:
Elapsed Time: 00:00:02
Read more
