Archive
Hi there,
This morning I have checked Event Viewer and I discovered this fatal error. I don’t know what is causing this because it seems like is not affecting anything at this moment. Any solution for this error ? What it means and is really affecting something ?
Thank you !
Event 36888, Schannel
A fatal alert was generated and send to the remote end point. This may result in termination of the connection. The TLS protocol defined fatal error code is 10. The Windows SChannel error state is 1203.
Read more
Hi there,
During the install of Exchange server I had this error and I followed the link below and no solution. I tried to reinstall and is not working. Does anyone have a solution for this error ? How can I solve this ?
Thank you !
Event Properties – Event 1024, MsiInstaller
Product: Microsoft Exchange Server – Update “Update Rollup 4 for Exchange Server 2010 Service Pack 2 (KB2706690) 14.2.318.2” could not be installed. Error code 1603. Windows Installer can create logs to help troubleshoot issues with installing software packages. Use the following link for instructions on...
Read more
I am having a problem while comparing two tables owned by different users on different databases on different servers when running from command prompt. The tables are different and I don’t know why is nothing to compare. Can anyone help me please to fix this ?
Thank you !
ERROR
Nothing to compare!
OK
Read more
Hi Friends,
I get this error message when I try to launch an application in the client machine. When I try to install the Adobe Reader 7.0 in the machine, I got this error message. The error says the package requested could not be found in the system data store or the file associated with this package could not be found on the server. Is the problem with the server? Please help. Thanks.
Application Virtualization Error
The Application Virtualization Client could...
Read more
After the system upgrade and scan, I ended up with an error message when I try to open the Microsoft Office Outlook. To my knowledge, I did not change anything with Outlook. For the past two days, I am not able to check the mailbox. Whenever I try, I get this error message. I tried to restart the system but nothing helps. Please help. Thanks.
Cannot start Microsoft Office Outlook. Cannot open the Outlook
Window. The set of folders cannot be opened. Errors have been detected in the file
C:UsersRobertAppDataLocalMicrosoftOutlookOutlook.pst. Quit
Outlook and all mail-enabled...
Read more
After the Microsoft Dynamics CRM 2011 installation in the Windows operating system when I am trying to register a plugin, I ended up with an error message. The error message states ‘please check the Registration Log for more information’. The details provided by error message are not helping me to fix the problem. Help please. Thanks.
Registration Error
There was an error while registering the selected plugins. Please check the Registration log for more information.
Would you like to see the details for this error?
Read more
Hi Tech savvy,
I have this problem for quite long time. I have Microsoft Exchange in Windows XP operating system. I do not understand what happened or what went wrong. The error says ‘Directory is invalid. Directory not found. Cannot backup directory’. Really I am in help. Please assist me solve this problem. Thanks in advance.
Errors
Click an error below to locate it in the job log
Backup- \POSTIONMicrosoft Exchange Mailboxes
V-79-5734-65033 – Directory not found. Cannot backup directory Craig Binney
[craigb] and its subdirectories,
V- V-79-5734-65033 – Directory not found. Cannot backup directory  Santa claus
[santaclous] and its...
Read more
Hello Experts,
Recently I upgraded my system with new software Microsoft Equation 3.0. The installation and setup went pretty well and good without any problem. However, the problem triggered when I start to work with it. I got an error message ‘this program has performed an illegal operation and will be shutdown. If the problem persists, contact the program vendor’. Please help me to solve this problem. Thanks.
Eqnedt32
This program has performed an illegal operation and will be shut down.
If the problem persists, contact the program vendor.
EQNEDT32 caused an invalid page fault in module EQNEDT32.EXE...
Read more
Hi experts DBA’s,
While working in a project when I try to connect to a SQL Server 2008 I stuck up with an error message. It says that cannot connect to the server. I have the all authorities to connect to the server but still it says cannot connect. Do I need to try with a different person? Please help me. Thanks.
Connect to Server
Cannot connect to ja8fxeakf.ctp.database.windows.net.
Additional information:
An exception occurred while executing a Transact.SQL statement or batch.
(Microsoft.SqlServer.ConnectionInfo)
Invalid object name ‘sys.configuration’. (Microsoft SQL Server, Error: 208)
Read more
Hello troubleshooters,
When I try to install the Remote Agent for Windows servers, I ended up with an odd error message. I am not aware of this error problem in the past. For your information, I have Windows 8 operating system 32-bit and 500GB hard disk. I am not getting any help from the error report. Please do the needful to rectify this error. Thanks a lot.
Install Error
FATAL ERROR: Error 1935. An error occurred during the installation of assembly.
‘Microsoft.VC80.MFCLOC,version=”8.0.50727.762”,processorArchitecture=”amd64”,publickKeyToken=”1fc8b3b9a1e18e3b”,type=”win32”. Please refer to Help and Support for more information.
Read more
