Archive
I am using two OS in my HP pavilion 15 laptop, window-7 and Ubuntu 14. In windows 7 my wi-fi is showing and working properly but in Ubuntu problem is occurring from last few days. It is not showing Wi-Fi network at all. Is there any configuration problem or anything else? Please suggest some way to fix this issue.
Read more
Using whatsapp in my HTC one mini M4. Everything is working fine with my whatsapp but downloading of media content is automatic even after disabling. I have disabled auto download from both wi-fi and mobile-data but still voice messages are getting downloaded. Please suggest some way to stop voice messages getting downloaded every time.
Read more
Using Spice MI 506 smart phone. Everything is working fine but when I downloaded Blobby Volley app in my phone and tried to play this game with my brother using Bluetooth then I am not able to connect my phone with my brother’s phone using Bluetooth. My Bluetooth device is working as I can send media content to my brother’s phone using Bluetooth. Please suggest some solution for this problem.
Read more
I am using Samsung wave-3 but it does not have android app store as it has bada OS. I want to install android in my phone. There are many blogs over internet showing that it is possible but I am not able to do this. Is it even possible? I also want to know is there any possibility of phone getting dead? Please suggest some way to do this is safe manner so that my phone does not dead.
Read more
I am using Idea 7.2 Mbps Net setter for internet connectivity. I have unlocked it and using Tata DoCoMo sim in it. It is working fine from many days but now it is not working. It is not even showing network of any Sim. I don’t know what has happened. Is the problem solvable or not. Please suggest any method if possible.I am using HTC Desire 210 which is working fine except its camera.Few days ago when I started the camera application on my phone, the application get dumped and doesn’t get started at all. I...
Read more
I am using HTC Desire 210 which is working fine except its camera.Few days ago when I started the camera application on my phone, the application get dumped and doesn’t get started at all. I switched OFF/ON my phone multiple times but the camera application is not working at all. Please suggest some way to fix this issue.
Read more
I'm sure there's more than likely a thread for this, but I've googled all night and nothing helped me. I'm at a loss here. I'm running windows 7 32bit,whenever I try to add a virtual drive it starts off normal,but then says "unable to add virtual drive" WindowsFixIt or whatever it was called,did not fix it. Any suggestions would be lovely,I used to run Daemon Tools lite on windows XP smoothly before I reformatted. I don't want to use a different program as Daemon Tools is what I know . help!
Read more
Every time I select to open an .iso file with Daemon Tools, I get an error stating "Windows Can Not Find F: Make Sure You Typed The Name Correctly, And Try Again." I have used Daemon Tools on other file types with no issues & had done Iso files in the past with no problems as well. Whats going on here? Please Help, Thanks.
Read more
I am running NOD32 AV 8.0.301.0. If I run Depth Scan not as an Administrator, I get a list of files in the log with an error opening message. However if I run the same scan as Administrator, then nothing shows up in the scan log. When using version 7 of NOD32, I used to get these entries in the scan log even when running it as Administrator. Is this a bug in version 8 or was version 7 incorrect?
Read more
I'm using Eset Nod 32 antivirus, Windows 8.1 64 bit. Today I found w32.Sality virus from an USB drive, it looked like the virus affected the MBR (Master boot record). I tried all the antivirus softwares and they detected the virus, but they are can't clean it. I must repair the drive MBR by myself. Is there a good Antivirus program that can prevent/clean the MBR virus from Windows? Is there any GUI tool for repairing MBR for USB?
Read more
