Archive
I tried to install Beyond CVS Plug-in for Eclipse on my Helios Eclipse version. I am have eclipse on my Windows 8, 64bit machine with 4GB or RAM and 200 GB hard disk space. When I try to configure the external merge tool, I get this error. I tried to uninstall eclipse and re-installing again but no joy. I tried restarting the machine and reconfiguring all the parameters but same problem. Anyone have similar problem please help. Will greatly appreciate. Thanks.
An error occurred while trying to compare revisions
Exception: The beyond compare executable could not be...
Read more
I am trying to play some of my stuff in Winamp yesterday and there are a few problems with it. I am getting this waveOut output v2.1 (d) error. It tried to play for a few seconds and then it goes frozen. The problem here is with the XBMC which will not play the film. I am not sure if it is a configuration issue. I am running this on my Windows 7, 64bit machine. I tried to uninstall WinAmp and re-installing it but no joy. Please help. Thanks.
WaveOut output v2.1 (d) error
Unsupported PCM format...
Read more
I have Windows 7 PC, 64bit with 8GB or RAM. I downloaded Symantec System Recovery 2013 and was trying to install on my machine. While it was trying to install and moved on to progress menu, it throws up an Install Error saying Fatal Error: Error 1402. Could not open key:” Not sure what this error means. I am reluctant to play around with the Registry. Is there any tool that I can use to fix this error? Please help. Thanks.
HKEY_LOCAL_MACHINESOFTWARESymantecBEGLLogging.Verify that
You have sufficient access to that key,...
Read more
Hello Experts,
I have Windows 8, 64bit and recently installed Inkscape on to my PC. When I tried to run Inkscape, its giving me an error saying “The application was unable to start correctly (0xc0000005). Click OK to close the application”. I tried uninstalling the application and reinstalling but it won’t work. Just to add that I upgraded my PC from Windows 7 to Windows 8. Could this be the problem? Please Help. Thanks.
The application was unable to start correctly (0xc000005). - Click OK to close the application.
Read more
I am using Windows 8.1 preview version OS, 64bit and having 4GB of RAM. Although I have been using Avast which is installed in my PC for a couple of years now, recently it’s come up with a major problem and gives me the error “The instruction at 0x7600ee1freferenced memory at 0x004589ff. The Memory could not be read”. I am suspecting it’s something to do with the operating system itself but not quite sure. I tried to recover my system and did a fresh install. I also tried uninstalling Avast and re-installing but of no joy. Anyone have similar...
Read more
I am having Windows 8 PC, 64bit with 8GB or RAM. Today I tried to download Avira Free Antivirus and attempted an install on my machine. When trying to run a scan, its giving me an error saying “Unknown error <-857735115>”. I tried uninstalling and re-installing the application but the problem still persists. I also tried restating the machine, also tried to recover the OS and no joy. Please help thanks.
Read more
Recently I had purchased Adobe CC to be installed in my Apple PC. I had logged in as a normal user and tried to install the Adobe CC product by opening the autorun facility in the install cd. After a few second during the install it popped up with this error asking me to uninstall and reinstall the product. I tried uninstalling and reinstalling several time, but gives me the same error. I am not sure if any of the files on the cd or corrupt or something. I would greatly appreciate if someone could help me solve this...
Read more
I am having a Windows 7 system and using AutoCAD mechanical 2013 which is installed in my system as administrator. I also have AutoCAD 2014 also installed on the same computer. When I open one of them it gives me the “AmMgdInterop.dll” error. If I uninstall both versions and install only one version, it won’t give me this error, but both versions seems to find problems with co-existence. Any reason why this is happening? Please help. Will greatly appreciate! Thanks.
Unhandled exception has occurred in a component in your application.If you click continue,the application will ignore...
Read more
Yesterday I had downloaded Adobe Premiere Elements from Adobe website and was trying to install the download on my Windows 7, 64bit machine with 6GB or RAM. It was a fresh install on my Windows 7 OS and it warns me that “We have detected generic Microsoft’s display driver on this machine. To get a better and faster playback performance, please update your display driver. – Display driver details: Microsoft Corporation – GDI Generic 1.1.0”. Having said that, it works fine, but gives me this error which I am worried about. Please help to get rid of this message....
Read more
I have a Windows 7 PC, 64bit with 4GB or RAM. Recently I downloaded KMPlayer from the internet and installed it on my machine. When I try to install the download, it gives me this error saying:
“KMPlayer.exe - Bad image. C:Windowssystem32URL.DLL is either not designed to run on Windows or it contains an error”.
I Went on to the website again and re-downloaded the install two times and I get the same error. Not sure why it says bad image. Anyone here please help. I would greatly appreciate any help. Thanks.
C:Windowssystem32URL.DLL is either...
Read more
