Archive
Hello experts,
 I am using Windows 8 Pro 64 Bits in my Computer, an ASUS F3SC. I have installed NVIDIA Driver and working very well. When I install Windows Essentials 2011 or 2012, Windows Live Movie Maker does not work, giving the message in attachment. I really need your help.
Thanks
Sorry, Movie Maker can’t start. Make sure your computer meets the minimum system requirements before trying to start Movie Maker again, and then try to update the driver for your video card if Movie Maker still doesn’t start.
What are the system requirements for Movie Maker?
Learn More.
Read more
I have a new Nikon D800 from Amazon, but I am facing some problem while uploading and editing videos in windows live movie maker. It says that it can’t be recognized.
It shows a red x on the video.
For my Nikon, I use 1080 HD (1920 by 1080).
Please help,
Thank You.
The file E:videonikon051.mov is not a supported file type, and it cannot be imported into Windows Live Movie Maker
Read more
Hi experts,
I am having trouble with the following error today. I reinstalled the program but could not fix this issue so please help me to fix this problem.
The program can't start because MF.dll is missing from your computer.
Try reinstalling the program to fix this problem.
Read more
I received an error message when, I connected successfully to my Windows 7 computer using Remote Desktop from a Windows XP box. I ran Windows update after the installation of Office 2007 and the following error message appeared. Help me to with possible solution to fix this issue.
An authentication error has occurred (Code0x80090308). Remote computer 192.168.10.103
Read more
Hello experts,
I am having trouble with OpenOffice program and giving me some unknown error using this program. I can’t understand this error so I will be very thankful to you if any help would come from you. Thanks in advance experts.
OpenOffice.org 2.0 Erreur lors de I’enregistrement du document A-Z Teminaisons.odt: Erreur d’ecriture. Erreur D’ecriture dons le souns-document styles.xml.
OpenOffice.org 2.0
Erreur d’ecriture.
Read more
I am using the latest version of Office program and using Microsoft Outlook I changed the settings for the auto reply but it displayed the following server error. Any help would be appreciated.
Your automatic reply settings cannot be displayed because the server is currently unavailable. Try again later.
Read more
I have created a report using Infopath so it works fine for some machines but now when I tried to open the same report in my Windows XP OS it displayed the following error message. I can’t open the new form to create further reports so suggest me with helpful solution.
Microsoft Office InfoPath
InfoPath cannot create a new, blank form.
InfoPath cannot open the form. To fix this problem, contact your system administrator.
Read more
I was currently using the “Import to a SharePoint List” for my working purposes but during the Import step I received the following error message. I don’t know the reason of this error so I need your help to demolish this issue. Thanks in advance.
Import to windows SharePoint Services list
Method ‘Post’ of object ‘IOWSPostDat’ Failed
Read more
I was using the latest version of AVG without having any issue but when I updated to 2013 free edition, then I launched Outlook and it crashed. I received the following error message from Outlook. Now I extremely need your help to resolve this issue.
Microsoft Office outlook
Outlook experienced a serious problem with the ‘avg exchange extension’ add-in. If you have seen this massage multiple times, you should disable this add-in and check to see if an update is available. Do...
Read more
Hi experts,
I am using Windows XP OS and getting fetal error message using Maya software. When I attempt to save it gives me the following error message. I need your help to fix this issue as soon as possible. I am grateful to you.
Fatal Error. Attempting to save in c:/DCUME~1/UNIADM~1/LOCALS~1/Temp/uniadministrator.20090805.1108.ma
Read more
