Archive
Hi experts,
When I am attempting to connect to the iTunes Store, I see this error. I want to demolish this error message so help me to fix this issue. Thanks.
Error Message: iTunes could not connect to the iTunes Store. An unknown error occurred (11333)
Read more
Hi experts,
 I am having trouble using iTunes, I am getting the following error message: Could not purchase “iTunes Match”.
An unknown error occurred (5002)
I tried many times to resolve this error by searching on internet but can’t find any solution.
I want to resolve this issue as soon as possible so any suggestion would be helpful.
Error Message: Could not purchase “iTunes Match”. An unknown error occurred (5002).
There was an error in the iTunes Store. Please try again later.
Read more
I am having problem while installing a network printer. When the install process tried to copy the printer drivers from a network share I encountered a copy error. I reinstalled this program to resolve this error message but I can’t do anything without your suggestion so help me to fix this problem. Thanks in advance.
Error Message: Setup cannot copy the file hpcp3525.CF_.
Ensure that the location specified below is correct, or change it and insert ‘HP Color LaserJet CP3525 PCL Printer Driver Disk’ in the drive you specify.
Read more
I encountered the following error message when opening some PDF files. I have updated Adobe Acrobat/Reader to the current version 10.1.4 or 9.5.2. The contents have not displayed at all while opening PDF. I really need help to resolve this problem.
Error Message: Insufficient data for an image.
Read more
 I originally just uninstalled the client and reinstalled it, didn't fix the issue. Then I uninstalled client and all plugins and started installing them one by one, until I found the vdr plugin is the one causing this issue. To confirm I uninstalled vdr plugin...no error......reinstalled vdr plugin....error.
Versions:
VDR 2.0
vCenter Server 4.1
VMware Client 4.1
Has anyone seen this before? I haven't really been able to find too much from searching.
Error Message: Method not found: ‘VMware.VimServices.Search.ResultItem
VMware.VimServices.Search.ResultPage.get_Result()’.
Read more
Hello experts,
 I have a problem with ASuite and SuRun. I don’t think so that I can fix this issue using Liberkey. Every time when I tried to start the program, I received an error message. SuRun is a part of ASuite so I hope you can fix this issue.
Thanks in advance.
Error Message: Access violation at address 00000958. Read of address 00000958
Read more
I have installed VDP on my server but when I try to log into the VDP via the Vcenter web client. When I clicked on "Connect" I have received the following error message which I can't get back in. Help me to find the solution so that I may come back in my life.
An internal error has occurred – Error #2130.
Reloading the client is recommended, so as to clear any problems left by this error.
Click Yes to reload the vSphere Web Client
Read more
Hello experts,
I received an error message 2147483650 when I opened tally. How to fix this? Any help would be appreciated. I am using Windows OS. Thanks.
File: ‘C:Tally.ERP9Data11112TranMgr.900
Position: 6542848
Chars: 512 (done 0).
Error Code: 2147483650
Read more
 I reinstalled Windows7 after trying the developers preview since there was still a lot of work to do for the preview. But suddenly I find myself with the following error message. Every time I boot up my system. Msiaux32.dll is sort of missing. I tried to Google it, unfortunately Google can’t show any results, now I know it’s quite related to a RunDLL, so I used ccleaner to fix registry but still unable to resolve the issue. Please help.
Thanks in advance.
Error Message: There was a problem starting msiaux32.dll. The specified module could not be found.
Read more
 I am having Configuration Advanced SystemCare error but on step 2 it gives me the following error message. I uninstalled the program to fix this problem but after a fresh install it gave me the same error. I am running Vista 64bit. Has anyone encountered a problem similar to this? I need suggestion to fix this error.
Error Message: Unable to write to CUsersAlexAppDataRoamingIObitAdvancedSystemCareMain.ini
Read more
