Archive
 I have Windows 8 Enterprise 64 bit International English- Office 2013 Professional Plus 32 bit English and WinZip 17 64 bit. When I launch Outlook 2013, I get the following error message. Any help would be appreciated.
Error Message: What happened:
WinZipAddin.Outlook.AddinModule error: the add-in has fired an exception
Where presumably this happened:
An error occured in the code of Add-in Express .NET (MS Office) library. See 'Details' section to get more detailed information about the error
Read more
I recently purchased Silent mail but after I installed it on my pc I got an error message after I started outlook. When I uninstall Silent Mail the error box doesn’t pop up any more. I extremely need you suggestion to fix this issue.
Error Message: Failed to load option. Error code 2
Read more
Hi experts,
I am having problem with my login details using Outlook Express. I know I enter the correct login details but when I enter these details after some time, the following error message appears. I will be really grateful to you if you may give me any solution to resolve this problem.
Thanks in advance.
Error Message: The server has rejected your login. Please verify that your user name and password are correct.
Read more
I am trying to retrieve newsgroup list from server function but it shows empty file. After some time the message is given that, the list is retrieved, but there is nothing to show. I tried many times to get this list with different ways but I need the expert advice. Can you give me any suggestion to fix this problem?
Thanks in advance.
Error Message: Unable to download the list of newgroups. An error has occurred.
Read more
I received the following error message when I tried to import my email messages from Outlook 2007 to Windows Mail. I reinstalled the program to resolve this error but could not find any result. Have any idea to resolve this error message? Really, need your suggestion.
Error Message: Messages cannot be imported from the MAPI client. An error has occurred.
Read more
Hi experts,
I got the last time OE crashed. This happens about every couple of days. OE version is version 6. Should I somehow uninstall it and then download it from microsoft.com and re-install it? I am waiting for your suggestion. Thanks.
Error Message: The exception unknown software exception (0xc0000008) occurred in the application at location 0x7c964ed1.
Read more
Recently I did a mistake when I was trying to install the Office Advantage add-in for Microsoft word. It prompts something when Word starts up but I did not find any advantage from this act. Once installed, I received an annoying error message. The error is shown below. Have any idea? I need your help to remove this error. Thanks in advance.
Error Message: The function you are attempting to run contains macros or content that requires macro language support. When this software was installed, you (or your administrator) chose not to install support for macros...
Read more
I have received the following error message when attempting to deactivate/activate or remove a user account from the Dashboard. I also experience a problem where the account unexpectedly disappears from the Dashboard list of users. The account is still listed in Active Directory and still a valid account but it is not displayed in the dashboard. Any suggestion would be really helpful. Thanks.
Error Message: An unknown error prevented the wizard from retrieving the user account information. If this problem persists, restart the server, and then try again.
Read more
While sysprepping my golden image for my VDI collection I got the following error message. Now tell me how to fix this problem? Have any idea?
I will be really grateful to you.
Error Message: A fatal error occurred while trying to sysrep the machine.
Read more
Hello experts,
The problem came in as I was setting up a new desktop tower I had ordered for her. I began to clean out some of the preinstalled junk , setting up some favorites, and transferring some of my favorite tools so I could remote assist with the Windows 7 easy connect .
After uninstalling the preinstalled 60 day Trial of Norton (what ever version it was) and then installing the Microsoft Security Essentials , I decided to try my service controller application to make sure it still worked. It failed with an error of “Can not open MsMpSvc service...
Read more
