Archive
BlueJ 2.1.3 is giving me the following error message which says “illegal start of expression”. Is there any way to fix this issue? Any help would be really appreciated. Thanks.
Illegal start of expression No help available
Message
No help available
OK
Read more
Hi experts,
PGA TOUR Pro Updater - What is with the mysterious error? The drumroll has got to go! Can you provide me the proper solution to resolve this error? I extremely need your help to demolish this error. Thanks in advance.
pdating PGA TOUR Pro failed… mysteriously. Try it again--and if it fails again, please call our customer support
Sorry, but you got a (drumroll) Mysterious Failure!
Updating PGA TOUR Pro failed… mysteriously. Try it again--and if it fails again, please call our customer support.
OK
Read more
I got the following error message when I was sorting my email messages. Why should I try again later? What is the error? How can I fix this issue? Any help would be really appreciated. Thanks in advance.
An AOL error occurred
America Online Error
An AOL error occurred. Please try again later.
OK
Read more
I was trying to burn a project onto a physical digital media disc using VideoStudio ProX5, the "Unspecified error 5.0.0" appeared at the end of the burning process. Can anyone tell me the reason of this error? How to fix this error immediately? I really need your help to resolve this error. I am using Windows 7 OS. Thanks.
Unspecified Error 5.0.0
Corel VideoStudio Pro
Unspecified Error
OK
[5:0:0]
Read more
I am getting the following error message when I try to open the disk in DVD Shrink. I have got a homemade DVD+R dual layer disc I wanted to put onto a DVD-R single layer. How can I resolve this issue? Any idea would be really appreciated. Thanks in advance.
Overlapped I/O operation is in progress.
DVD Shrink 3.2
DVD Shrink encountered an error and cannot continue.
Failed to open file “C:Documents and SettingsGavDesktopVIDEO_TSVTS_01_0.IFO”
                                        OK
Read more
When I add the script to document I get the following error message “Error opening release script “Alfresco Kofax Release Script". Any help would be really appreciated to resolve this error. Thanks in advance.
Error opening release script “Alfresco Kofax Release Script” for batch class “Alfresco Test” and document class “Alfresco Test Document Class."
Kofax Capture Administration
OK
Read more
Hi experts,
I am facing Custom UI run time error in Norton AntiSpam outlook plug-in. I have installed Microsoft Office 2010 on my Windows 7 OS. How can I resolve this issue? Can I get the solution step by step to fix this issue? Any idea would be greatly appreciated. Thanks in advance.
Are you facing Custom UI run time error in Norton anti spam outlook plug-in?
Error found in custom UI XML of “Norton Antispam Outlook Plug-in”:
Line: 10
Column: 68
Error Code 0x80004005
“violates minLength constraint of ‘1’.
The attribute ‘label’ with value “failed to parse.
Read more
I am getting an error message with Error code 7044 when I try to shadow a session with XenApp v6.0. How can I resolve this error message? Can anyone provide me the solution to fix this issue? Any help would be really appreciated.
Thanks in advance.
Shadow failed. Error Code 7044
(Error 7044 - The request to control another session remotely was denied.)
Read more
Hi experts,
When I try to shadow a session with XenApp v6.0 then I receive the error message “Shadow failed”. Provide me the proper solution step by step to resolve this issue. I would be really grateful to you.
Thanks in advance.
Shadow failed. Error code 120
(Error 120 - This function is not supported on this system.)
Read more
I am getting the following error message while executing any setup created with InstallShield Prof. 7.01. Why am I getting this error and how can I solve this annoying error? I really need your help to resolve this issue immediately. Any idea would be greatly appreciated.
An error (-5004 : 0x80070005) has occurred while running the setup. Please make sure you have finished any previous setup and closed other applications
An error (-5004 : 0x80070005) has occurred while running the setup. Please make sure you have finished any previous setup and closed other applications. If the error still...
Read more
