Archive
I have installed a full version of Avira Premium Security Suite but recently, I am getting the following error message. I don’t know how to change configuration without having any problem. I uninstalled the program to resolve this problem but again the same error appeared. Any help would be really helpful. Thanks.
Exception: ACCESS_VIOLATION (0×0000005) at address 0×76019b90.
avconfig
Exception in modul AVCONFIG.DLL (09.00.00.31):
Plugin: Firewall (Page=2)
Function: configPagePreTranslateMessage
Extended information:
Product: Avira Premium Security (EN), 392
Operating System: Windows Vista () [6.1.7600]
OK
Read more
VideoReDo: Don't know why I can’t make any conversations. Someone help please. The following error message appears during output. Any help would be really appreciated. Thanks in advance.
Graph abort in: Output muxer, error: TS Muxer Error, packet data buffer is full
VideoReDo
Problem encountered during Output!
Graph abort in: Output muxer, error: TS Muxer Error, packet data buffer is full. Mux rate may be too
        OK
Read more
I cannot install on vista 64, what’s wrong? I got an error message, what’s the problem? An older TotalMediaExtreme Trial (with TotalMedia Theatre) worked fine before. I really need your help to fix this issue. Can you provide me the proper solution? Thanks.
Cannot find ‘HDNavigateCore.dll’. Please, re-install this application
Themida
application
OK
Read more
As the subject says, I'm getting a license error when trying to start up 3ds Max 5. During installation, this pops up. I couldn't find a solution to this problem. Please Help. Thanks
There has been an unexpected error with the license Management system
3ds max 5.1
Management system. Please contact your system administrator
Or dealer. Error [436:4:1]
OK
Read more
I ran into this error recently with a rig that’s using more memory than 3D's Max’s current threshold.
What can I do to fix it now?
I extremely need your help.
Subsequent errors will not be reported
Bitmap Filter Error
Failed to allocate filter tables for this bitmap. Not enough memory. This bitmap may render incorrectly.
Subsequent errors will not be reported.
OK
Read more
I am using Sony Vegas Movie Studio Platinum 11.0 but recently, I received the following error message while creating the media file on it. I think Sony is unable to fix this problem and shows the error. How can I fix this error? Any help would be greatly appreciated to resolve this error. Thanks in advance.
An error occurred while creating the media file VincentLaforet_Choice_b.wmv
Vegas Movie Studio HD Platinum 11.0
An error occurred while creating the media file VincentLaforet_Choice_b.wmv.
The system is low on memory. You may be able to reduce memory usage by closing other applications.
OK
Read more
Hello experts,
Pencil Animation this happens every time while exporting a new project. Can anyone provide me the solution to resolve this annoying error? I really need your help to demolish this error. Thanks in advance.
Error: Could not find the root index
Flood fill Error
Sorry! This doesn’t always work. Please try again (zoom a bit, click at another location.. )
If it doesn’t work, zoom a bit and check that your paths are connected by pressing F1.).
Error: Could not find the root index.
OK
Read more
An error occurred while doing a project Using GStreamer. The Error message is in below image. Any idea what to do? Any help would be really appreciated. Thanks.
Error While Rendering Project
GStreamer encountered a general stream error.
Qtdemux.c(4035): gst_qtdemux_loop (): /pitivi+utils+pipeline+Pipeline:pitivi+utils
+pipeline+pipeline1/GESTimeline: gestimeline1/GESTrack:gestrack3/
GnlComposition:gnlcomposition3/GnlURISource:gnlurisource1/
GstURIDecodeBin:internal-uridecodebin/GstDecodeBin:decodebin7/
GstQTDemux:qtdemux6:
Streaming stopped, reason not negotiated
        OK
Read more
I really hope someone could help me with this. I've read some of the other Help Forum posts where someone said they had a problem opening the video and tried the solutions on offer but still no luck. When I try to open some of my .avi files in Aegisub, I get this error. Any help would be really appreciated. Thanks.
Ffmpegsource video provider: Failed to open
Error Setting video
ffmpegsource factory: Ffmpegsourcevideo provider: Failed to open
video track:
avisynth factory: AviSynth error: FFVideoSource: Codec returned zero
size video
OK
Read more
Hi experts,
I have downloaded avidemux_2.5.3.tar.gz to update my old version of avidemux but when I've tried to install I got this error. I was wondering if anyone has a suggestion to resolve this problem, or another way to update it. Thanks in advance.
Error
Package/home/zxoc/bin/avidemux-2.5.3-3.pm.4.1.×86_64.rpm could not be installed.
Details:
Subprocess failed. Error. RPM failed: warning: /home/zxoc/bin/avidemux-2.5.3-3.pm.4.1.×86_64.rpm: Header V3 DSA signature: NOKEY, key ID 9a795806
error: Failed dependencies:
avidemux = 2.5.2-3.pm.4.4 is needed by (installed) avidemus-gtk-2.5.2-3.pm.4.4 ×86_64
OK
Read more
