Archive
After an installation of Nitro Pro 8, I seem to have a license error. I got this error message, “84: Error - Originally Licensed on another computer.” How can I solve this problem?
Thank you everyone.
-84: Error - Originally licensed on another computer
Read more
Hello all.
I have the version 3.75 of the IrfanView. I decided a version update to 3.8, so I went in on installed it right over when I got this error message popping up on me. Please help me find a solution for this.
Thanks in advance.
IrfanView Setup
Can't install all files!
Please check your destination directory lot lice space!
OK
Read more
Greetings people.
I was installing the version 3.3 of PhotoScape when I received an error code/ message. What is happening? I am using Windows Vista.
Please help me fix this.
PhotoScape.exe - Application Error
The application failed to initialize properly (0xc01500004). Click ok to terminate the application.
Read more
Hello there.
I am using Desktop Manager version 5. It asked me for an upgrade to version 5 so I did. During the whole installation process, it somehow got interrupted and seem to cannot finish the installation. And when I loaded it up again to use the version 5, it automatically prompted for the installer upgrade. Any thoughts on this? Is there workaround?
Thank you!
BlackBerry Desktop Software Installation Information
Please use Setup.exe for installation instead of BlackBerry Desktop Software.msi
Read more
Hello friends.
I got this SBR2 error that keeps bugging me every time I run SRB2.exe as an installation. Does this mean that there’s supposed to be a SBR1? It comes with an exe file named SRB2Src.exe that appears to be a winrar file but I didn’t run it. Any ideas why this is happening?
Thank you in advance.
SRB2 error
signal_handler(): segment violation
Read more
Hi all,
I kept on bumping into this Xenocode 2008 error. I think it has to do when I run CCleaner. Any thoughts on this?
Thank you everyone.
Xenocode Postbuild 2008
The application encountered an error: (0xD0000002)
Please contact the publisher of this application for more information.
Read more
I am getting a pop-up error message from ASCTray.exe every time I start my computer. I have set CCleaner as part of my startup programs and when I click on it, there goes the message again. This happens on every computer restart I make. I would greatly appreciate any help.
Thank you so much.
ASCTray.exe
An error occurred in the application
Read more
I keep on receiving Registry Cleaner error that has something to do with Regcleaner.exe. But the thing is, I have already removed Regcleaner.exe from my system. Registry correcting applications such as CCleaner, REgScrub Vista and Spybot doesn’t do much. Please, anyone help me on this.
Thanks in advance.
Eusing Free Registry Cleaner
Access violation at address 004097F3 in module ‘Regclener.exe’. Read of address 00AEC348.
Read more
I ran GTA IV, and it was doing well. It functioned great. Then there was a Live update prompt, otherwise I’d be playing offline, so I did the update.
Hamachi has this “cannot connect to engine error,” when I tried to install it. At the beginning, the installation would seem to be working fine, but when it’s nearly done, a message window would pop-up.
I was frustrated so I tried to look for a solution in the web. I Googled it and what I got was a great number of “registry errors.” I used CCleaner to see if I have registry...
Read more
Hello people,
I was trying to install the MS Web Platform but run into an error (please see below). I believe that to install this, there is some sort of connectivity during the phase. It downloads a catalogue of products from the Microsoft site. Then a window popped with an error message. What do you think is happening?
Is there a way to fix this?
Microsoft Web Platform Installer
Unable to download the Web Platform product list from https://www.msn.com/nl-nl/?ocid=NEFLS000.
Check your network connection and try again. If the problem persists, report the issue on the Web Platform Installer forum at:
Read more
