Archive
Hi experts,
I am trying to connect Informix database through SSIS in Windows x64 environment.
I searched from the internet to find the proper way to do it but could not find any way. What to do now?
Any help would be really appreciated.
Install Anywhere has detected that you are installing the 32 bit
Prerequisite Verification
Prerequisite Verification checks failed
Product on a 64 bit machine
Prefix path with C:WindowsSysWOW64 and restart the installer.
                                                        OK
Read more
I have created a Class Library project and added OA model and few Firebird tables in it. It works properly then I added RIA Services Class Library project to solve, but I am unable to add OA Domain Service. I cleaned and rebuild the entire solution after each change. I have attached the error message. Any help would be really appreciated. Thanks.
Type converter initialized failed
Error
The metadata for field...
Read more
I am using Windows XP OS and I receive the following error message using the Firebird. What I do to fix it? Can you provide me the best solution to resolve this problem? I would be grateful to you. Thanks.
Database file appears corrupt
Error
Unable to retrieve user list.
Detail Message:
Database file appears corrupt (C:PROGRAM
FILESFIREBIRDFIREBIRD_2_1SECURITY2.FDB)
wrong page type
page 67 is not wrong type (expected 6, found5)
database file appears corrupt (Ăéæı)
OK
Read more
I’ve uninstalled Babylon but every time I start the computer this error shows. This is really irritating. What can I do to fix it? Any help would be really appreciated. Thanks in advance.
Bbylon Error
Bbylon Error
String.dat file is missing or corrupted.
OK
Read more
I am using Windows XP OS and recently, I got the following internal error message. It says that FrameMaker has detected a serious problem and must quit. I don’t know how to fix it. Can anyone has an idea to resolve this problem? Any help would be appreciated. Thanks.
Internal Error 7004, 6055410, 7657059, 0,
Error
Internal Error 7004, 6055410, 7657059, 0, FrameMaker has detected a serious problem and must quit.
A file named “c:program filesadobeframemaker7.0Framelog_06.03.08_12.35.05.txt” has been generated contains information that may help Frame development improve the product for future releases.
Please describe your recent actions and send this, along...
Read more
I was working on ConfigMgr 2012 RC2 deploying an App-V package then I received the following error message when trying to deploy an App-V package to a client. Can you provide me the solution to resolve this error? I really need your help to fix this issue. Thanks.
There was a problem applying changes to the software
Software Center
Unable to make changes to your software
There was a problem applying changes to the software. You
can try again. Or, if the problem continues the information
that is shown in the following section can assist your help
desk in troubleshooting
Click OK to return...
Read more
I was creating a 1/3DvDrip of one of my DVDs... The Created file had the following attributes...
But on trying to re-encode or 448kbps using VirtualDub using the AC3 ACM Codec at 3/2Channels, I get the following error message. Have you any idea to fix it? Thanks.
The audio codec cannot compress the source audio to the desired format.
VirtualDub Error
Error initializing audio stream compression:
Check that the sampling rate and number of channels in the source is complete with the selected compressed audio
format.
OK
Read more
I have installed Xvid 1.22, when I open an Xvid encoded .avi with virtualdub 1.9.5 x64 in windows 7 x64 rtm
Any idea how I can fix this?
VirtualDub requires a video for Windows (VWF) compatible codec to decompress video
Virtual Dub Error
Couldn’t locate decompressor for format ‘XVID’ (unknown)
decompress video. DirectShow codecs, such as those under by Windows Media Player, are not suitable.
OK
Read more
I appointed this because of the most popular features such as folder monitoring. I cannot test MusicBee at the moment because I am having this pain. How to resolve? Any help would be really appreciated. Thanks.
Attempted to read or write protected memory. This is often an indication that other memory is corrupt
Error
An unexpected error occurred:
OK
Read more
SignTool displayed the following error message. The error image is attached below so please help me to resolve this error immediately. Thanks in advance.
An error occurred while signing (signtool.exe).
Digital Signature
OK
Read more
