Archive
I often receive the following error message when try to create the directory while attempting to install VIPRE. How can I create the directory properly? I have tried many ways to resolve this error by reinstallation and online searching but still getting this error. Help me with best solution. I would be grateful to you.
Error 1317. An error occurred while attempting to create the directory C:ProgramDataMicrosoftWindowsStart Menu
Read more
Hi experts,
I am getting the following weird and annoying error message while logging into process designer (IBM BPM V8.0.1). The error shows after entering the credentials. The reason says “Password expired”. Can I get the proper resolution and process to reset the password of DB? Any help would be really appreciated.
Thanks for any suggestion.
Could not get JDBC Connection; nested exception is java.sql.SQLInvalidAuthorizationSpecException: Connection authorization failure occurred. Reason: Password expired. ERRORCODE=-4214, SQLSTATE=28000 DSRA0010E: SQL STATE =28000, error Code =-4,214
Read more
The program has been aborted due to the Fatal MAExplorer error. I click on save as to fix the problem as shown on screen shot. I can’t understand how to fix this problem properly so please provide the guidance to resolve the annoying error. I would be grateful to you for any kind of assistance.
DRYROT Status Has Been Saved C:jwsMAExplorermaeReportmaeDRYROTmessage.txt Please E-mail this saved file to [email protected] so we can try analyzing and fixing the problem. Click OK to exit MAExloprer
Read more
Hi experts,
I am unable to create object store at or access to the database file is not allowed. What could be the reason? How can I remove these errors? I have searched online but need your assistance so guide me properly.
Access to the database file is not allowed.[File name=] Unable to create object store at C:program filesaltirisBarcodeManagerDataPermissions Test
Read more
I am unable to use Virtual Machine properly and the error says that‘ Failed to clone the virtual machine’. Is this problem with a server? I have tried to start it manually but could not fix the problem. VM’s are on DRBD. What’s wrong? I need help.
Failed to done the virtual machine RSD_Centros5_5_x86_64_A
Cannot register the image C: program filesoraclevirtualboxvboxGuestAdditions.iso with UUID {0bda623d-b3cd-4e9a-b639-6acd8a611456} because a cd/dvd image C:program filesoraclevirtualboxvboxguestadditions.iso with UUID {0bda623d-b3cd-4e9a-b639-6acd8a611456} already exists
Details
Result Code: VBOX_E_INVALID_OBJECT_STATE (0x80BB00007)
Component: VirtualBox
Interface: IVirtualBox {c28be65f-43b4-81f1-eb60cb516e66}
Read more
Today, I was configuring MySQL Server 5.5, but I received the following error message during the process of configuration.
The process was going well but at that service start an error displayed saying “Cannot create windows service for MySQL.Error: 0”.
Can I get the best solution?
I am waiting for your suggestion.
Thanks in advance.
MySQL Server instance configuration
Configure the MySQL Server 5.5 server instance
Processing configuration..
Prepare configuration
Write configuration file (c:program filesMySQL server 5.5my.ini)
Start service
Cannot create windows service for MySQL.error: 0
Read more
I was using Hyper-V Manager and working fine but now an error occurred while attempting to start the selected Virtual Machine. The error shows “Demofail2 failed to start”. What is wrong with the selected virtual machine? I am using Windows 8 Operating System so please help me to resolve this issue.
An error occurred while attempting to start the selected virtual machine(s).
Microsoft Emulated Controller (instance ID 83F8638B-8DCA-4152-9EDA-2CA8B33039B4): failed Power on with Error the system cannot find the file specified
Attachment C:UsersPublicDocumentsHyper-VVirtual Hard DisksDemofail2/vhdx not found Error: The system cannot find the...
Read more
I have installed 32bit version of RapidGenerator on my system but today an error message displayed during the file read and Process failed. How can I fix this memory issue? Have any idea or suggestion to resolve the problem? I really need an expert’s advice. Please help me.
Process failed
Java.lang.Exception
Can’t read file C:tempexcel.xls.HRESULT=080004005, Unspecified
Items: 0
Unique parts: 0
Source data imported: 2%
Import time: 0 h 0 min
Read more
I am trying to debug plugin registered for online version and installed Plugin Pro-filer in the plugin registration Too. I registered the plugin and step on the Microsoft Dynamics CRM server. I performed the operation in CRM that causes the plug in to run but the plugin showed an exception and the Business Process Error dialogue displayed.
Business process error
Unexpected exception from plug-in (Execute): CrmOnlineErrorLogging.TestPlugins: System Exception: Error logging
Read more
I can’t use Socket address using Serva32 and it gives me the following annoying message “Error 10048 Only one usage of each socket address (protocol/network address/port) is normally permitted”. Why can’t Serva32 bind the SNTP port? What could be the main cause? I need your assistance. Help me immediately with best solution.
Error 10048
Only one usage of each socket address (protocol/network address/port) is normally permitted.
Serva32 cannot bind the SNTP port
An application is already listening on this port
Read more
