Archive
I upgraded NI-Switch to NI-Switch 4.0 or later but after that I noticed the multi-module NI-Switch Handshaking program no longer works properly. I get the following error message when I try to start a session with the second Switch. Now I am looking for the solution to resolve the error below. How can I overcome this problem? I need your help.
Thanks in advance.
Error: error -1074107494 occurred at niSwitch Commit.vi Possible reason(s): No registered trigger lines could be found between the devices in the route. If you have a PXI chassis, identify the chassis correctly in...
Read moreHello,
Star c3 communication software error "CAL Error number 870". Is there any way to resolve the following error? I searched for the solution to fix this issue but I could not find anything for the resolution. I am expecting assistance from you so guide me with the proper solution.
I would be grateful to you.
Error: Internal error: Communication software error (CAL error number 870) Please contact the star DIAGNOSIS user help desk.
Read moreHi,
Loading 5.1 FLAC produces silent audio When try to load 5.1 FLAC both with ffmpegsource or avisynth and different avisynth downmixers the resulting audio in Aegisub always is silent, audio spectrum also is clean. Can I fix the following error message? Assistance would be really appreciated.
Bundle of thanks.
Error: ffmpegsource factory: FFmpegSource audio provider: Failed to index: Invalid initials pts and dts avisynth factory: AviSynth error: DirectShowSource: couldn’t open file Z:CANAAN~1.FLA: He “ shown images “
Read moreHello,
I received the following error message when I tried to install The Official DSA Theory Test for Drivers of Large Vehicles. The error message pops up after the 100% installation. What could be the cause for this error? How can I resolve the issue? I reboot the computer but error still remains. Any idea would be really helpful.
Thanks for everything.
Error: Error 1935.An error occurred during the installation of assembly ‘Microsoft.MSXML2,PublicKeyToken=”6bd6b9abf345378f”,version=”4.1.0.0”t,type=”win32”,processorArchitecture=”x86”’. Please refer to Help and support for more information.
Read moreHello,
I am getting the Windows error message 1303 during the installation of NI Software. Why does the installer show this error message even I am logged in as administrator. What is the cause of this issue? Is there any way to run this Software successfully? Any assistance would be really appreciated.
Bundle of thanks.
Error: NI MetaSuite Installer: Error 1303. The installer has insufficient privileges to access this directory: C:Program Files (x86)National InstrumentsSharedMIFMetaSuite. The installation cannot continue. Log on as administrator or contact your system administrator.
Read more
Currently I am doing some mash-up tunes for the up coming competition. My crew and I bought an Adobe Audition for me to be able to mix it up more using this software. While combining some tunes an error saying that “The instruction at ‘0x50662e62” referenced memory at ‘0x008f0cc8’. The memory could not be “read’”. What is this error? How will I be able to bypass this? Help guys.
I am using Windows Vista OS SP2 32-bit and tried to scan to PDF but I receive an error message, which said“try to reinstall the software”. I reinstalled the software to fix the following error message. The processes of the installation begin but then i get this error message:
Error: "E:setuphpzprl01.exe" -m preloadrecoverymechanism "-*" ".autorun_network... The system cannot find the path specified.
Read moreHi experts,
I am experiencing the issue out of the blue where the where the fingerprint reader constantly disconnects, only to reconnects itself moments later. The following error message appears when it disconnects and shows “fingerprint device is not present” Whenever I attempt to open the protector suite software. Any help would be appreciated.
Thanks in advance.
Error: An internal error occurred (bpwb: bp-wb-dpi-ed-wbebu(900106ba)). Details E7210001 An internal error occurred (bpwb: bp-wb-dpi-ed-wbebu(800106ba)).
Read moreHello,
Using Ubuntu Software Center on Ubuntu 11.10 I had the same error while trying to install Google Chrome stable release using Ubuntu Software Center. Is this the problem with the encrypted home directory which cause the internal errors? Can I fix this issue? I am waiting for your suggestion.
Error: Internal Error The file”/home/linuxnov/Downloads/google-chrome-stable_current_i386.deb” could not be opened.
Read moreHi,
I tried to launch the Microsoft Special Effects Software the following error 103 message appeared. Why do these kinds of errors refer to QX5 microscope? I reinstalled the product could not fix this issue. I disconnected the microscope and reboot my computer then reconnected the microscope but the problem remained same. I would be grateful to you.
Thanks in advance.
Error: An error has occurred. Make sure your microscope is connected, then try restarting the application. If you are still having problems, disconnect your microscope, reboot your computer, then reconnect your microscope. (103)
Read more
