Archive
I received the following error message constantly when I was scheduling a live meeting for one of my training sessions using Microsoft Office. I never faced this type of error before, and I could not solve this problem searching online for a long time. I hope you can fix this issue so provide the assistance.
I would be grateful to you.
Error: An error occurred while executing this command. If this error persists, please contact your Live Meeting administrator.
Read more
Inventor installation fails with Error 1309 reading from CCUpdateTool.dll Recently an installation of the Product Design Suite Premium 2013 was stalling at Inventor with a Microsoft Installer error 1309 like this: I couldn’t find the resolution so I need your help to fix this.
Thanks in advance.
Error: Error 1309. Error reading from file: E:x64inventorProgramFilesAutodeskInventor 2013BinCCUpdateTool.dll. Verify that the file exists and that you can access it.
Read more
Hi experts,
X64 code with /debug:parallel links against x86 Parallel Debugging DLL (PDBX.dll) Developing under Win7 Pro x64 + VS 2008 Pro. If I enable /debug:parallel in my x64 program, it crashes with: The application was unable to start correctly (0xc000007b). Click OK to close the application If I check my exe with Dependency Walker, I see that it has linked against the x86 PDBX.dll and x86 LIBIOMP5MD.DLL. Obviously this leads to the crash. I've uninstalled, reinstalled all of VS and Parallel Studio (sp1, composer update 4). How can I fix this? Have any idea?
Error: The...
Read more
I received the lots of JavaScript errors as shown below when I tried to update the nu-get packages for my newly created MVC4 website. Is there any way to resolve the following issue? I really need your help as soon as possible. Any assistance would be appreciated.
Thanks in advance.
Error:
Unhandled exception at line 115, column 5 in http://localhost:15657/Scripts/jquery.unobtrusive-ajax.js 0x800a01b6 - JavaScript runtime error: Object doesn't support property or method 'live'
Read more
Why am I receiving a 'HTTP Status 401: Forbidden' error when attempting to upload to Cisco Discovery Services?
'HTTP Status 401: Forbidden' error when attempting to upload to Cisco Discovery Services The CCO account has not been configured in the DesignXpert installation.
How to configure the CCO account?
Thanks for any assistance.
Error : Network Assessment Error
Failed to submit network assessment query.
Check server error message below for more details
Click on help to see possible causes or solutions
The request failed with HTTP status 401: Forbidden.
Read more
A serial number must be specified by the client' error is being displayed when I try to update. CDS Error: Current user does not have permission to change the status for the given TransactionID When updating, an error message is displayed stating the following, How can I resolve this issue? Any help would be appreciated.
Error: Netformx Updater
A serial number must be specified by the client. Please contact Netformx Technical Supportfor further assistance.
Read more
Intel® C++ Compiler and Intel® Array Building Blocks (Intel® ArBB) both install tbb.dll and tbb_debug.dll on the Windows* OS. I install Intel® C++ Compiler (either the stand-alone product or as part of, say, Intel® C++ Composer) and I have a system that already has Intel® ArBB, then I see this following "Entry Point Not Found", like this: Have any idea for resolution?
Error: The procedure entry point ?destroy@task_base@internal@interface5@tbb@@SAXAEAVtask@4@@z could not be located in the dynamic link library tbb.dll.
Read more
Why am I receiving a 'Failed to generate' error when attempting to create a document from DesignXpert? Failed to generate .doc' Error with Office 2010 I have Microsoft Office 2010 32 bit installed (64 bit is not supported at this time). Can I get the solution to resolve this issue? I am waiting for your assistance.
Thanks in advance.
Error: Failed to generate PRS0436-111107-Network Discovery-Network Assessment Summary Document.doc
Read more
I got the following error message when I got the latest version of our automated test with some files checked out to me.
The error displays saying that there are unresolved conflicts.
Can I fix this issue without reverting back my current version? I already have a new recording now I want your assistance to resolve the error.
Error: Some files were not updated because of unresolved conflicts.
Read more
Using Windows 7 HP-AIO Computer, when I restarted, I got a message that I had 3 recommended alerts.  In the "HP Advisor" I selected the "! 3 Recommended Alerts" and when I clicked "Run", the HP Total Care screen came on, and flashed "Gathering Information" and then gave me the following error message:   I've tried a few times and keep getting the same error message.
Error: Object reference not set to an instance of an object.HPSF at HPAssistant.Data.dsActiveCheckRes.loadAcData(String FilterCategory,Boolean includeIgnored) At HPAssistant.Pages.MaintainActions.Page_Loaded(Object sender, RoutedEventArgs e)
Read more
