Archive
Using Felix with Office 2010 on files downloaded from the Internet Office 2010 has a new feature called Protected View. This protects you from potentially dangerous files downloaded from the Internet. If you open a file in Office 2010 that was downloaded from the Internet, you’ll see something like the following warning at the top of the document. Have any one solution to fix it?
One of the effects of this protection is that it disables all macros and add-ins, including Felix. If you try to use Felix in this state, you’ll get the following error:
Error: COM...
Read moreHello,
I have gforce gtx260 graphic card dx 11 & latest Nvidia driver installed but an error message appeared “please enable Direct3D acceleration”. I reinstalled the driver but the same error displayed as shown below.
I searched the resolution from the internet but I could not resolve the issue.
Any suggestion would be really appreciated.
Thanks in advance.
Error:
Please enable Direct3D acceleration. You can do this by starting dxdiag and enabling Direct3D acceleration in the Display1/2 tab after installing DirecX8.1b (or later) and the latest drivers for your graphics card.
Read moreHello,
I am trying to run the label wizard using Microsoft Access 2007, but I get the following error message when click on Create → Labels. How can I resolve this error? Is there any way to fix this? Provide the step by step solution.
I would be grateful to you.
Error: Error in loading DLL
Read more
Hello experts,
I just started to get the same D3DEngine error: "Please check publishers website for tech support Details: [Error locking VB]" upon installing the latest Nvidia drivers (195.62) for my GeForce 8800 GTS 512.
When I try to open and start kudos the error comes up. How can I fix this? I am waiting for your assistance.
Error:
Read moreHi,
When I tried to activate Office 2010 subscription license (licensed through office 365 E3 Plan) I got the following error message on my PC. I also checked for the reason of this error but I couldn’t find. Can you tell me the reason of this error? How can I remove this error? I need your help to fix it. I have tried uninstallation/reinstallation process but nothing happened.
Thanks for any assistance.
Error: Microsoft Office Subscription Error An error has occurred impacting your Office subscription. Learn more about this error or contact your support team with error code...
Read moreHi,
I unzip this file to the server location FDOT2010VBA folder the file I unzip is Office2010VBA.zip. I searched this error from the internet for the resolution but I couldn’t solve this problem. How can I fix this issue? Provide assistance.
Error: Compile error in hidden module: frmPickExcel
Read more
I encounter an error message when reinstalling Microsoft Office Starter 2010 - ThinkCentre, ThinkStation, ThinkPad, Value Line, how to remove this error? I have to remove this error as soon as possible. What is the cause of this error? Help me to resolve the matter.
Thanks in advance.
Error: There was a problem setting up Microsoft Office Starter 2010: This product must be installed to Q:. Ensure that Q: is unused and try again.
Read more
When Microsoft SoftGrid client tries to start an application, I receive the following error message due to the unsuccessful attempt to start an application. I tried many times to fix this issue but couldn’t solve. How can I use this application without having any issue? Any help would be greatly appreciated.
Thanks in advance.
Error: The SoftGrid Client could not launch the application you requested. The specified application does not exist. Please check the name you specified and try again. Error code: 420114-0B206004-00000A09
Read more
I have just installed to the latest update 7.11 and I got the following error when I tried to run the software. I can’t fix this issue without expert’s advice. Any assistance would be really appreciated so guide me with proper solution.
Bundle of thanks.
Error:
Python function terminated unexpectedly No module name stylize (Error Code: 1)
Read moreHi,
Excel web access an error has occurred share Point 2007
One of our users gets the following issue when accessing a given.xlsx file in a document repository. The enduser can access other files in the same repository fine. We're not using Excel Calculation Services. The enduser is using Office 2010 (x86). Our SharePoint farm is 2007. Using share point if the document originator copies the file from one location to another, the enduser is able to access it. It's just weird. Have any idea?
Error: An Error has occurred. Please contact your system administrator if this problem persists.
Read more
