Archive
When I began to start Office 2013 the Word gave the following server error trying to insert the pictures. The error displayed the following “Sorry, we are having some temporary issues. You can work offline if you plan to insert pictures from your computer.” What is wrong? How can I solve this problem? Help me please!
Read more
Recently, I have installed Microsoft Office Professional Plus 2013 and it works fine unless I reboot my computer. When I reboot my PC the configuration process starts and the following error shows “Microsoft Office Professional Plus 2013 did not complete successfully”. How can I remove this error? Suggest me.
Thanks in advance.
Microsoft Office Professional Plus 2013 configuration did not complete successfully.
Error 25004. The product key you entered cannot be used on this machine. This is most likely due to previous Office 2013 trials being installed. (System error: -1073418218)
Read more
Hi experts,
I am running Windows 8 Operating System and decided to install Office 2013. I downloaded the program successfully but when I attempted to install Office 2013 an error message displayed. I started the program again and tried to use the Repair option but could not fix the problem. Any help would be greatly appreciated.
Couldn't install office
We're sorry something went wrong while we were trying to start your program.
Please try starting your program again, or use the Repair option from the Programs and Features item in your Control Panel if it still won’t start.
We're sorry...
Read more
Recently, I have checked the Office 2013 preview App-V package but now I decided to install the application directly. I received the following error message when I attempted to install the Office 2013 package directly. I uninstalled the program but I could not fix this issue. How can I get the proper instruction to install it?
Thanks for any help.
Microsoft Office 2013 does not support upgrading from a preview version of Microsoft Office 2013. You must first uninstall these preview versions of Microsoft Office 2013 products and associated technologies:
Office 15 Click-to-Run Licensing Component
Read more
I am attempting to install recently purchased download version of Microsoft Office 2010 Professional Plus. Each time I get the following error message when I enter the key (#) for the installation process but the setup can’t open the registry key. Can you provide me the proper details of installation and how to fix this issue? Any suggestion would be greatly appreciated.
Error:
Error 1402. Setup cannot open the registry Key
UNKOWNComponents1CF85317B34E1D111AF7000A9CA05BF00004109E60090400000
Verify that you have sufficient permissions to access the registry or contact Microsoft Product Support Servivces (PSS) for assistance. For information about how to contact PSS, see
C:UsersSTEPHE1AppaDataLocalTempSetup00000e98PSS10R.CHM.
Setup failed....
Read more
When I was using a writer document the LibereOffice crashed suddenly. Now I can’t open any document and getting errors again and LibreOffice quits. How can I remove the following series of errors? Can I get the solution to resolve this issue? Help me to fix this issue.
Thanks in advance.
Error:
An error occurred on LanguageTool 1.0.0
java.lang.RuntimeException: Failed to load rules: Loading rules failed: Duplicate class definition
de.danielnaber.languagetool.rules.CommaWhiteSpaceRule, found in
C:Program FilesLibreOffice3program..shareextensionsLanguageToolLanguageTool.uno.jarStacktrace:
De.danielnabber.languagetool.JlanguageTool.getAllBuiltinRules(JlanguageTool.java:245)
De.danielnaber.languagetool.JlanguageTool.<init>(JlanguageTool.java:155)
De.danielnaber.languagetool.openoffice.Main.doGrammarCheckingternal(Main.java:263)
De.danielnaber.languagetool.openoffice.Main.doProofreading(Main.java:242)
OS:Windows XP on x86, Java version 16.3-b01 from Sun Microsystem Inc.
Error 2:
An error has occurred in LanguageTool 1.0.0:
Java.lang.NullPointerException
Stacktrace:
De.danielnaber.languagetool.openoffice.Main.doGrammarCheckingInternal(Main.java:274)
OS:Windows XP on x86,Java version 16.3-b01...
Read more
I am using Office Professional Plus 2010 and have downloaded office suite 2010 sp1 but when I attempt to install this SP I then the following error message. I am using Windows Operating System and could not solve this problem even by reinstallation. I need expert’s advice to resolve the issue so any help would be greatly accepted.
Error:
Microsoft Office 2010 Service Pack 1 (SP1) There are no products affected by this package installed on this system.
Read more
Today, I have encountered a strange error when opening the Source Control Explorer. Microsoft Visual Studio shows “Team Foundation Error”. Can I get this program without having any issue? I have tried to solve it by searching but I really need your suggestion to resolve the error. Any assistance would be appreciated.
Thanks in advance.
Error : Team Foundation Error Method not found: 'Boolean Microsoft.TeamFoundation.VersionControl.Client.Workspace.OwnerNameMatches(System.String)'.
Read more
Nobody is aware with this error in SharePoint 2010 I checked log file. This error is coming. Please help me to resolve the following error message so that I may continue my work.
I would be grateful to you.
Error :
There has been an error while loading the form. Click Try Again to attempt to load the form again. If this error persists, contact the support team for the Website. Click Close to exit this message. Invalid field name. {35363960-d998-4aad-b7e8-058dfe2c669e}/ssp/Lists/Tasks Correlation ID: a3d4a3b7-b3f9-4ba0-b919-aee0b799d367
Read more
SmartAssembly 6 Robust .NET obfuscator I am using this software including error reporting mechanism of Smart Assembly but I get the following error message any time when the software crashes. How can I fix this issue? Is there any way to resolve the error? Please provide the assistance to resolve this problem. Any help would be greatly appreciated.
Thanks in advance.
Error:
.NET Reflector has encountered a problem. We are sorry for the inconvenience. Translation failure in (Byte, String) : String’in ‘SmartExceptionsCore. Version=5.0.0.0. Culture=neutral, PublickKeyToken=7f465a1c156d4d57’. Please tell Red Gate Software Ltd. About this problem. To help improve the...
Read more
