Archive
Hello experts,
I got the following Profile Mismatch error when I was trying to copy and paste image data, or copy drag an image using the move tool. Is this the problem with colors mismatch? I have tried to search the solution but I need expert’s advice to resolve this issue permanently. Any suggestion would be really appreciated.
Paste Profile Mismatch
Are you sure you want to convert colors to a destination document with a color profile that does not match the current RCB working space
Source: sRCB 1EC61966-2.1
Destination: Display
Read more
I get the following error message when I try to connect a 150GB drive via Firewire to my Macbook 13. When I click on “Force” it seems to work and I can read and write but how can I remove this error? I want to fix it immediately.
Thanks in advance.
NTFS-3G: Volume not cleanly unmounted
The NTFS volume that you’re trying to mount (/dev/ rdiskOs3) has not been unmounted properly. This may mean that the volume is in an inconsistent state, and mounting it with NTFS-3G could lead to data loss....
I get the following error message when try to download the AIR update. I have attempted to install this application again but I cannot install it. How can I fix this problem? Have any idea? Any help would be greatly appreciated.
Thanks in advance.
Sorry, an error has occurred.
The application could not be installed. Try installing it again. If the problem persists, contract the application author.
Read moreI am trying to Activate Kaspersky Internet Security, but I get the following error message when I enter the activation code it throws me this error during the progress of activation. I have tried many times to resolve this but could not.
Can I get the resolution to active?
What could be the problem? I am waiting for your help.
Thanks in advance.
Number of activation using this code exceeded.
Read moreHi,
I am continuously getting the following error message and literally have my computer shutdown.
I have added more 1GB of RAM and 8GB SD card for Power boost but the error still persists.
You can I avoid this low memory error message?
I really need your help to resolve this issue.
Thanks for any assistance.
Close programs to prevent information loss
Your computer is low on memory. Save your files and close these programs:
Rage
Read moreHi experts,
I am getting the authentication error and can’t log on to Windows. When I log on manually the fingerprint works once only than I get the following error message during fingerprint enrollment. Any suggestion would be greatly appreciated.
Thanks in advance.
An error occurred during fingerprint enrollment. Please try to re-roll this fingerprint.
If you continue to receive this error, please contact technical support.
Read moreHello,
I had downloaded Norton antivirus for my PC but now I want to remove this application but I am having problem to remove it and reinstall this software. The following error message appears during the uninstallation and reinstallation process. How can I avoid this error message? I want your help.
Thanks in advance.
Norton Remove & Reinstall
Could not download the installer layout. Click here for information on how to uninstall and reinstall your Norton product manually.
Read moreHello,
Today, I am receiving the Internet Explorer Script Error message every time I boot my PC. I have configured Google Chrome as a default browser then why is IE showing this error message? I want to remove this error immediately. I really need your assistance to fix it.
Thanks in advance.
Script Error
An error has occurred in the script on this page.
Line: 13
Char: 3
Error: 's' is undefined
Code: 0
URL: https://us.norton.com/
Do you want to continue running scripts on this page?
Yes No
Read moreHi,
Recently, I downloaded the game but when I tried to play this game the following weird message appeared in German as you can see in attached image. What could be the reason? Can I remove this error immediately? Have you any idea?
Thanks for assistance.
Zugriffsverletzung bei AdresseOO4O66D3 in Modul ‘Omsi.exe. Schreiben von Adresse FFFFFFF9.
OK
I recently downloaded Nitro PDF Reader but when I attempted to install the Setup an error message appeared saying “An error occurred during the installation of assembly”. How can I install it properly without any error? Can I get the trusted link to download this software? Any help would be appreciated.
An error occurred during the installation of assembly ‘Microsoft.VC80.CRT,version=”8.0.50727.4053” ,type=*win32* ,publicKeyToke*1fc8b3b9a1e18e3b* ,processor Architecture= “x86”. Please refer to Help and Support
for more information. HRESULT: 0x80070002.
Read more
