Archive
Hi experts,
When I try to open a raw format file for Retouch Hasselblad 3F scanner in Photoshop CS6 an error message appears like a weird attack. Is this a problem with software? How can I overcome this annoying error? I am expecting a great help from you. Any king of help would be greatly appreciated.
Thanks in advance.
Photoshop cannot open this file.
If you are attempting to open a raw file from a digital camera, make sure you have the latest Camera Raw update installed via Help > Updates…
If the problem persists, visit the following link for...
Read more
I have successfully downloaded the CS6 on my Windows 7 OS but when I tried to install it an application error message appeared. It said that the application was unable to start. How can I remove this annoying error so that I may continue my project? Any suggestion would be worked like a charm.
Thanks in advance.
The application was unable to start correctly (0x000007b). Click OK to close the application.
Read more
I have installed Adobe Photoshop CS6 Extended on my Mac machine. It worked fine for 3 months ago but recently, I got the following error message when I attempted to crop an image using this software. I could not understand the cause for the error. I really need your help. I would be greatly appreciate your help.
Could not build the Crop preview because of a program error.
Read more
Hello experts,
I have installed Adobe Illustrator in my Mac machine now I am attempting to open CS5.1 file in CS6 but an unknown error has occurred. Should I change the file name or installed the CS5? Any suggestion would be really helpful. I am waiting for your reply experts.
Thanks in advance.
An unknown error has occurred.
Read more
I have installed Windows XP OS 64-bit and I have downloaded Adobe Photoshop CS6 both in 32 and 64 bit. When I attempt to run a 64 bit version I get the following configuration error message which says uninstall and reinstall the product. This time I uninstalled the product then reinstalled it again but the same error message appeared. What is wrong with this product? Can you provide the proper solution?
Bundle of thanks.
Configuration error
Please uninstall and reinstall the product.
If this problem still occurs, please contact Adobe technical support for help, and mention the error code...
Read more
Hi experts,
I am using Mac OS and recently downloaded Adobe Illustrator CS6. I just tried to some nonsense attempt to open multiple files but it gave me this weird error message. I closed this program and open the selected file but the same error message appeared. Did I something wrong attempt? Help me!
Thanks in advance.
Unable to set maximum number of files to be opened.
Read more
Recently, I just got Adobe illustrator CS6 on my Windows 7 OS 64-bit but when I attempted to open it an error message displayed during the loading of this software. I tried to search solution from the internet but could not find anything. Please assist me to resolve this annoying error.
I would be grateful to you.
Error loading plugins.
IlluToQueu.aip
IlluToSignlab.aip
“Checkbox” Don’t Show Again.
Read more
Hi experts,
When I tried to install Adobe Photoshop CS3 in my Mac OS the system error messages appeared like an attack. The following error message shows “You are not connected to the Internet”. This error displayed when I called for the online help. I checked connection and working properly. The same error appeared with the Adobe illustrator. How can I remove this annoying error? Help would be really appreciated.
Photoshop Online Help could not be displayed because you are not connected to the Internet.
To access online help or to download help contents, you need...
Read more
I got the weird FTP error messages when I was trying to update a supportive site. I tried to log into a known server but the error messages came again and again. I entered all the login details and keys correctly but I think there is something wrong with this software. I am waiting for your reply.
An ftp error occurred – cannot make connection to host.
Read more
When I inserted the DMXzone Calendar 2 into the page where everyone can join membership Now, I received the following error message once I double click the Insert Record. I cannot edit the “insert Record” behavior. I am looking for the help.
Thanks
While executing onLoad in Insert Record2.htm, the following JavaScript error(s) occurred:
At Line 1202 of file “C:Program Files (x86)AdobeAdobe Dreamweaver CSS.5ConfigurationServerBehaviorsSharedEditOperations.js”: tag List[j].type has no properties
Read more
