Archive
I was trying to update my phone to IOS 6 BETA 3 Ota but the software update failed with the following error message. The error occurred downloading this software as you can see below the attached image. I need an expert’s advice so please help me with proper solution and guidance.
Thanks for everything.
Software Update Failed. An error occurred downloading iOS 6 beta 3.
Read moreHi experts,
I am getting the following error message on my Phone when I try to download updates an error message displays. The error shows that “iS3 Updater has failed to download updates”. I checked the internet connection and settings for date and time which may cause the error but they were all correct. Why am I getting this Update error? I really want to remove this issue.
iS3 Updater has failed...
Read moreHi,
I am running Windows XP SP2 32 bit Operating System and whenever I try to open Microsoft Office application or my computer starting up. What is wrong with the Mail Proxy? How can I fix it without having any issue? I am looking for an expert’s advice so please provide best solution to be accepted.
Thanks in advance.
C:windowssystem32inetsrvinetinfo.exe[PID 172] is using port 25.
Read more
I have installed 64 bit Microsoft Office 2013 on my system but during the installation I received the following error message. I have 64 bit OS but it shows this annoying message why? Do I need to install the software again? I would greatly appreciate your help.
Thanks in advance.
We found a problem!
We’re sorry, Office (32bit) couldn’t be installed because you have these 64-bit Office programs installed on your program:
Microsoft Office 32-bit Professional Plus 2010
Microsoft Office Office 32-bit components 2010
32-bit and 64-bit versions of Office programs don’t get along, so you can only have one type installed...
Recently, I downloaded Microsoft Office successfully but when I tried to run the Setup I get failed and received an unexpected error message. I looked for the additional help but could not solve the problem. I really need your assistance to resolve this matter. Thanks for everything.
Error
We’re sorry, something unexpected happened…
Go online to look for additional help.
Read moreHi,
I can’t activate my Windows while I get this error during the activation of Windows 8.
I tried to learn the activation process from the control panel but I can’t do anything without your help.
Can you provide me the step by step solution to activate my Window?
I would be greatly appreciated you help.
Thanks in advance.
Windows couldn’t be activated
Error code: 0x8007007B
Error description: The filename, directory name, or volume label syntax is incorrect.
Read moreHello experts,
I got the following error message while installing the Windows 8 using WDS but it stopped at the installing features.
Did I something wrong during the installation?
I tried again to install so that the error may disappear but nothing changed.
Can I get the proper way to install the Windows 8 OS?
Any help would be really appreciated. Thanks.
Windows installation encountered an unexpected error. Verify that the installation sources are accessible, and restart the installation.
Error code: 0xC0000005
Read moreHello,
When I try to update Windows I get the following error message. Can I get the solution to this weird error?
I really need your help while I have searched the solution for this error but could not find any result.
I hope you will be prove like a lucky charm for me.
Windows could not search for new updates
There was a problem checking for updates.
Error(s) found:
Code 8024401C
Recently, I decided to install the latest Windows 8 OS but when during the installation the computer restarted and displayed an error message. The error says that the Windows installation cannot proceed.
I restarted the installation but the same error appeared. Can I get the solution to demolish this error?
Thanks in advance.
The computer restarted unexpectedly or encountered an unexpected error. Windows installation cannot proceed.
To install Windows, Click “OK” to restart the computer, and then restart the installation.
Read more
During the installation of Windows 7 I have got an error message.
I can’t understand the following error message so please help me to resolve this error.
I reinstalled the Windows but the same error message appeared in the same place.
How can I overcome this annoying error?
Any help would be greatly appreciated.
Install Windows
Windows could not parse or process unattend answer file [C:WindowsPantherunattend.xml] for pass [specialize].
The answer file is invalid.
Note: This is an old post of 2009 but people still having this problem till September 10, 2012.
Read more
