Archive
Hi.
I am currently new to Adobe Premier Elements. I was used to work with Sony Vegas then I decided to try this software which is a somewhat down grade version of Adobe Premier Pro. Yesterday I did finish editing one of my videos using this software.
Now as I was trying to open it, it produces an error saying that the video I have edited could not be loaded, etc. Can anybody help me in this situation?
The project could not be loaded, it may be damaged or contain outdated elements.
Read more
Hello guys.
I am trying to create a CMS content for a client using PHP. Upon migrating the system to their server and error appears which I took the liberty on pasting it with this. How do I fix this error?
Thanks and more power.
I have shifted from using eDonkey to eMule. Upon starting the software for the first time an error occurred saying that it “Failed to create Incoming files directory “j:eMuleIncoming”-The system cannot find the path specified.’. Did I install the software wrong? What is the fix for this error?
Thanks in advance.
Failed to create Incoming files directory “j:eMuleIncoming” – The system cannot find the path specified.
Read moreHey everyone,
I am wondering if it is possible to use eon vue 6 scenes in modo? Will I be forced to get vu eXstream and C4D or one of the other apps Xstream integrates? Any help at all with this would be greatly appreciated.
Thank you very much in advance.
Read moreHey techyv,
I am currently writing a task organizer script and am having difficulties with marking the subtasks as complete or not complete. My code is:
Read more
Hey everyone,
I have installed the smart red hat on Linux and I've had no problem with it recognizing my integrated audio device while my Win98 does not find any drivers for it. Does anybody no how to solve this problem? Do drivers exist for an integrated sound card?
Thanks
I know that Samsung Wave II has a MP4/MKV/H.263/H.264/WMV/Xvid/DivX video player. Considering that it runs version 1.0 of the Bada operating system, I`m not sure if there is a free FLV player for it. Is there a way to Get FLV players for Samsung wave 2?
Thanks in advance.
Read more
Hey guys,
I usually work on PCs although I mostly use a MAC. When I download an .EXE file (usually a driver for a PC)
Netscape runs it and I see a lot of machine code printed in a window. Is there a way to do a mac to windows compression rather than execute it in Netscape?Read more
I am using Windows 7 SP1 64 bit and have a PHotosmart C410a but I am receiving the following error message whenever I apply a Windows update using Printer that was working fine but now it is not working properly. I have spent so many hours to resolve this issue but I need an expert’s suggestion for the best resolution. Help me to fix this problem.
Thanks in advance.
Error:
Error Situation Code: 30547925
The following lines were retrieved from the installation error logs.
+00000000000017686528|s|Now launching=X:hpzprl40.exe –inf –mpreload_drivers “-*Stub” “198140” “/rerun” “1” –lXXX –f
“X:hpoins52.dat” –Validate No t” –Validate No
Failed to add...
Read moreHello,
I get the error message every time when I try to upgrade Symantec Encryption Desktop to a latest version. What could be the causes of this annoying error? How can I fix it? Can I get solution which is useful without creating any problem? I am waiting for your suggestion. Thanks for any help.
Error in custom action. The library
C:Windows52A6BF9E857AE674B5555559AF8D.TMPWiseCustomCalla2.dll is invalid or could not be found.
Read more
