Archive
Recently, I have purchased my new PC and tried to install Intel turbo boost 2.6 but I got the following error message during the installation of this software.
I have tried many ways to resolve this error but I think I extremely need an expert’s advice to fix this problem immediately.
Prove a proper solution.
Thanks for help.
Can't find script engine "VBScript" for script "C:Program FilesIntelTurboBoostlauchhidden.vbs
Windows Scropt Host
"Can't find script engine "VBScript" for script "C:Program
FilesIntelTurboBoostlauchhidden.vbs".
Read more
In Developer Studio (JBoss Developer Studio) someone advise me to replace the line
-Djboss.discovery.directory.url=https://devstudio.jboss.com/updates/6.0/staging/devstudio-directory.xml with Djboss.discovery.directory.url=http://www.qa.jboss.com/binaries/RHDS/updates/development/6.0.0.Alpha1.extras/devstudio-directory.xml
in jbdevstudio.ini.
When I put an empty jbdevstudio-directory.xml file up on https://devstudio.jboss.com/updates/6.0-staging/devstudio-directory.xml, I am getting these errors. Is there any solution for it? Thanks for any help.
Connector discovery completed without finding any connectors. Please check your internet connection and try again.
No Connectors Found
Read more
AuthenTec’s fingerprint software Protector Suite shows this following error message at every launch. How can I solve this problem? Can anyone help me? I would be grateful for any kind of assistance. I am using Windows 7 Operating System. Thanks in advance.
Fingerprint software Arithmetic operation resulted in an overflow
Arithmetic operation resulted in an overflow.
Details
Error code:                                    ...
Read more
I Installed LabVIEW 8.2.1 on my PC, and drivers were from Vision Acquisition CD 8.2.1. Now I keep getting the following error when I am trying to install NI-IMAQdx RT 3.0, NI-IMAQ RT 3.7 and NI Vision RT 8.2 on a PXI-8106 Real-Time (RT) Controller.
This software installs and works fine on a PXI-8187. How can I use Vision on PXI 8106 RT controller?
NI-IMAQ server common 2.0.0 requires NIVISSVC 7.1.0
Cannot continue because of the following unresolved dependencies:
NI-IMAQ Server Common 2.0.0 requires NIVISSVC 7.1.0
NI Vision RT 8.2.0 requires NIVISSVC 8.2.0
NI-IMAQdx RT 3.0.0 requires NIVISSVC 8.2.0
NI-IMAQ RT 3.7.0 requires NIVISSVC...
Read more
I received the following weird error message when I tried to install the Trend Micro Titanium program. I could not understand the cause of this incomplete installation. How can I prevent this error without having trouble? I have tried to reinstall this application but the same error displayed. I need your help to fix it as soon as possible. Thanks for any help.
You receive the following error message when you try to install your Trend Micro Titanium program:
A problem prevented the installer from completely setting up Trend Micro Error code: #0, 1002, 0x000"
Trend Micro Titanium Maximum...
Read more
Recently, I have downloaded NiceLagel Suite and installed it properly but when I attempted to open this software I got the following error messages. First the upper error message displayed and then the other one. Can I get the resolution to solve this problem? I would be grateful to you. Thanks.
Access violation at address 00969BF8 in module 'nbars.dll'. Read of address 00000008
Application Error
Exception EAccessViolation in module nbars.dll at 00099BF8.
Access violation at address 00969BF8 in module 'nbars.dll'. Read of address 00000008.
OK
The application failed to initialize properly (0xc0000142). Click on ok to terminate the application.
nlabel5.exe...
Read more
An error encountered when attempted to open iTunes for Windows. The following error message shows “iTunes was not installed correctly. Please reinstall iTunes. Error 7 (windows error 193)” Can I fix this error without having any problem? I really need assistance to resolve this. Thanks in advance.
iTunes
Read more
Hello experts,
Today, I got the following error message when I was upgrading my TFD 2010 to TFS 2012. Is it the compatibility issue or something else? I want to resolve this issue and upgrade to a new version of TFS 2012. How can I fix it as soon as possible? Can anyone help me? Thanks in advance for any help.
COB_TFSBuildToolsCOB.Cl.dlll’ that can be placed on the toolbox
Microsoft Visual Studio
There are no components in
'C:COB_TFSBuildToolsCOB.Cl.Workflow.dll’ that can be placed on
the toolbox.
Read more
I have been using Virtualbox for quite some time now. I use it to run my Linux system over my Windows 7 system. Yesterday I tried to upgrade my system to the latest version. Now Virtualbox keeps on producing an error message which I took a screen shot of it.
How should I fix this error?
Should I rollover my current update/upgrade of my operating system?
Failed to start the virtual machine FreeBSD
Failed to load VMMR0.ro (VERR_SYMBOL_NOT_FOUND).
Unknown error creating VM (VERR_SYMBOL_NOT_FOUND).
Details
Result Code: NS ERROR...
Read more
My kid and I are really fond of playing browser games. One of the new games suggested that I update Java.
Upon doing so a message box appears with the following text I have posted here.
Is it necessary to update Java monthly or should I just do it manually?
Thanks in advance for your advice.
You have chosen to never check for updates and may miss future security updates.
We strongly recommend letting Java periodically check for newer versions to ensure you have the most secure and fastest Java experience.
Read more
