Archive
Recently, I have installed Kaspersky Security Centre to version 10 and everything is working fine except one thing when I accept the license agreement under “Software Updates”. Have you any idea related to this problem? I really need your help to resolve this issue. Thanks for any help.
“Error occurred when accepting selected license agreements”
Read moreHello,
Every time I receive an error message when try to install AutoCAD 2012. The error shows that “The Windows Installer Service could not be accessed. I installed this software properly but the error pop up. I have tried to reinstall the software but the same problem exists. What could be the cause? I want assistance. Thanks.
When Installing your Autodesk software you receive an error 1719 stating the following;
"Error 1719. The...
Read moreHello,
I have tried 3 times to install the Navisworks Service Pack 1 but every time I got the following annoying error message regarding the Navisworks 2011 32/64bit Exporter Plugins. How can I solve this problem? Thanks for any help.
When trying to install the Navisworks Service Pack 1 you receive this error message regarding the Navisworks 201132/64 bit Exporter Plugins.; and to verify that you have sufficient access to that key. But when you go to find this in your registry there is no application folder under HKEY_LOCAL_MACHINE/application/Navigator 2011.
Could not open key:
HKEY_LOCAL_MACHINE32\applicationsNavigator2011. Verify that you have...
Read moreHi,
I am trying to start IBM Clarity Studio which is a Desktop application has Microsoft Excel embedded. It’s a requirement to run this application. Excel has installed on my system but I got the error message starting Clarity Studio suggesting to install Microsoft Office. How can I fix this problem? Have any idea? Thanks for any help.
Cannot start Clarity Studio. Please install an Microsoft Office version greater or equal with Microsoft Office XP
Read moreHello,
Why am I getting this following error message whenever I try to access my mailbox through Outlook?
This error is very annoying to me and I can’t solve it easily however, I have restarted the program.
Can I get the resolution to fix it immediately?
I would be grateful to you.
Outlook.exe has generated an error and will be closed by Windows. You will need to restart the program. An error log is being created. Outlook will...
Read moreHello,
The following error message occurred when Leap Conveyancer tried to access Microsoft Word. I really need an expert’s advice. I have installed Leap Office Add-In but the error exists. How can I remove this error? Help me to fix it immediately. Thanks in advance.
LEAP Conveyancercannot communicate with Microsoft Word. Please make sure that the 'LEAP Office Add-In' is installed and enabled in Word.
Read moreHi,
I got the following error message when I was trying to install Microsoft Office. How can I install this software properly?
I have tried to reinstall this application to fix the problem, but I extremely need your assistance to resolve the error.
I am using Windows 7. Any help would be appreciated.
Setup
Error 1923. Service 'Office Software Protection' (osppsvc) could not be installed. Verify that you have sufficient privileges to install system services.
Read moreHi,
I have installed Movie Maker 2.1 and the files were imported good as well as clips in the collection. An error message encountered after some uninstall and reinstalls of ffsshow. The following error message displayed after the Movie Maker crashed. Can I solve this problem? Provide a proper solution. Thanks in advance.
Windows Movie Maker
Error signature
AppName: moviemk.exe AppVer: 2.1.4026.0 ModName: divxdec.ax
AppVer: 6.0.0.1571 Offset:00038cb5
Read moreHello,
Recently, I have installed Camtasia Studio but when I tried to import MP4 files an error message displayed saying “some required file are missing”. I reinstalled the application as shown below in the message but the same problem appeared. How can I fix this issue without having any issue? I want resolution. Thanks in advance.
Camtasia Studio
Camtasia Studio detected that Some filters are missing.
You may not be able to import MP4files. Repairing or reinstalling
the application may fix this problem.
OK
Read moreHi,
Autogk crashes whenever I try to run the .exe here's the message. It was working fine earlier today, I've installed a couple new programs and it suddenly stopped working. Anyone have any suggestions?
I've already tried uninstalling and reinstalling it.
Let me guess. One of the things installed was DivX 6.1? Because of that error message looks strange familiar. Help me to fix it. Thanks.
Application
Exception EConvertError in module AutoGK.exe at 00008ECA.
'.1.2' is not a valid integer value.
OK
Read more
