Archive
While attempting to install a program, I got an error on my Windows 8 machine. It says, "C:WindowsSystem32msxml3.dll is either not designed to run on windows or it contains an error. Try installing the program again using the original installation media or contact your system administrator or the software vendor for support". It seems like a registry issue and I am not really an advanced user and don't want to add any more harm to my computer so I am asking here. What should I do to fix this?
Read more
I installed Auto GK and found the following error message when tried to open MPEG2 video file saying “No video streams were found”. What could be the cause of this error? How can I open this file using Auto GK? Any help would be greatly appreciated. Thanks in advance.
Warning No video streams were found.
Warning
Read more
I am using DVD Fab and I am unable to run DVD Fab without using the run as admin option on Windows 7 pro. When I attempt to run this software I get this weird error message. Now I am trying to fix it but I can’t fix it without an expert’s advice and suggestion. Please help me. Thanks in advance.
Windows cannot find ‘C:pprogra~2DVDFAB~3optionsDVDFabAddonBluRay.exe’. Make sure you typed the name correctly, and then try again
C:PROGRA~2DVDFAB~3OptionsDVDFabAddonBluRay.exe
Windows cannot find ‘C:PROGRA~2DVDFAB~3OptionsDVDFabAddonBluRay.exe’. Make sure you typed the name correctly, and then try again.
Read more
Recently, I downloaded a video of mp4 format and I also downloaded AVI-Mux_GUI-1.17.8 to fix the out of sync audio problem but I found that the mp4 file is not supported in it then I tried to convert the video to .AVI so I loaded avidemux_2.5.2_full_win32 and tried to load the file but I got the following warning with the weird message. Have any idea to fix this problem? Suggest me properly. Thanks.
Confirmation H.264 detected If the file is using B-frames as reference it can lead to a crash of shuttering. Avidemux can use another mode which is...</p> <a href=Read more
I am having the following ProfileEditor.exe Windows error. I get this error message every time I start my computer or any program. The error shows the source file is corrupted. What could be the cause of this error? How can I fix it easily? Need your assistance. Thanks.
Error An error occurred while trying to extract ProfileEditor.exe The source file is corrupted.
Error
Read more
I am getting this error message every time I start my computer and it is unable to read a diskette, disk, or other disk in the computer. What does it mean? Have you any recommendation to fix this problem? I really need your advice as soon as possible. Thanks in advance.
I/O Error! Device: [2:0:0] TSST corp CDDVDW SH-S203N SB02 (F:) (SATA) ScsiStatus:0X02 Interpretation: Check Condition
I/O Error!
ScsiStatus:0x02
CDB: 2A 00 00 06 BE 60 00 00 20 00
Interpretation: Write (10) - Sectors: 441952 - 441983
Sense Area: 71 00...
Read more
I have DVD Fab and it was working very well but now first time I got an error message when I played the DVD from the drive and tried to back it up it started the scan and displayed this following error message. I tried all the below Retry, Abort, Ignore and Ignore All options but the same error appeared with the same process of the scan. Can I get resolution if you have any idea about this issue? I would be grateful to you. Thanks in advance.
Reading/Writing Error Control D: [RANJENI_ORAO_DVD_4]...</p> <a href=Read more
I got this error message when I was trying to rip a DVD using DVDFab even I am using the latest version of this software. What could be the reason of this error? Should I wait for another latest version of DVDFab HD Decrypter? Any help would be appreciated. Thanks in advance.
DVDFab To open the DVD disc, you need buy or renew DVDFab “DVDtoDVD”, or you can wait for new version of DVDFab HD Decrypter.
DVDFab
To open the DVD disc, you need buy or renew DVDFab “DVDtoDVD”, or you can wait for new version...
Read more
I am using Shrink 3.2 to Re-author and want to keep a functional menu which will prevent my backups from auto playing and starting immediately. I got this following error message when I was trying to drag the title of the movie. How can I resolve this issue? What should I do know? Is there anything wrong that I did? I need your help. Thanks.
Re-authoring Menus DVD Shrink cannot retain menu functionality when you re-author a menu. Instead, all menu buttons will be removed, and the menu will be converted into a regular video clip.
Re-authoring Menus
DVD...
Read more
I have installed DVD Shrink 3.2 on my system to rip/burn my DVD’s. Recently, I got an error popped up at 98% of analyzing using DVD Shrink. The following error message appeared and DVD Shrink cannot continue as stated in error below. How can I fix this problem and what is causing? Thanks for any assistance.
DVD Shrink 3.2 encountered an error and cannot continue.
DVD Shrink 3.2
DVD Shrink encountered an error and cannot continue.
Failed to read file “D:”
Copy Protection Error - The Read failed because the sector is encrypted.
Read more
