Archive
I am currently having issues with BCS, Metadata and Access Services in my SharePoint environment.
I have the issue with BSC once I open the SharePoint site in SharePoint designer and click on ‘External Content Type’ on the top menu and I got this following error message.
I have confirmed all the configuration settings but I could not resolve this issue.
Can I get resolution to fix this problem?
Any assistance would be helpful.
The Server was unable to process the request due to an internal error. For more information about the error, either turn on.
Microsoft SharePoint Designer
Some checks cannot be...
Read more
I have installed Windows 7 Operating System to test some apps on Windows 7 environment but I got an error message every time I try to launch any app. I can’t understand what is the cause of this error?
I just want to know about this and get the resolution to fix it as soon as possible.
Please help me to fix this Error Parsing.
Thanks for any help.
GfxUI.exe – Configuration parser error Error parsing c:<path>machine.config Parser returned error 0xc00ce556
Error parsing C:WindowsMicrosoft.NETFrameworkv2.0.50727configmachine.config
Parser returned error 0xC00CE556
Read more
When I logged into my account I get this following error message using Ubuntu.
The panel encountered a problem while loading. How can I remove this error immediately?
I really need your help as soon possible.
The panel encountered a problem while loading “NotificationAreaAppletFactory::NotificationArea”. Do you want to delete the applet from your configuration?
Read more
I am running Windows 7 Operating System and getting the following error message when trying to launch steam.
I am getting this error “Steam.exe (main exception): unable to load library steam.dll”.
Have any idea or suggestion?
Any help would be appreciated. Thanks in advance.
Error Steam.exe (main exception): unable to load library steam.dll
Error
Steam.exe (main exception): Unable to load library steam.dll
Read more
Why am I getting this error message when I try to install CRM 2011 for Outlook?
When I clicked on ‘OK’ the sequencer crashed. I have been tried many times to resolve this issue but I could not solve it.
I am confused how to fix it?
Please provide any assistance.
Thanks in advance.
SFTSequencencer.exe – Application error The instruction at 0x76f5e803 referenced memory at 0x89560024. The memory could not be read.
Click ok to terminate the program.
Read more
Hi people.
I keep on receiving a GSpot.exe pop-up systems error. What is it and what causes it?
Some say it has something to do with a certain “.dll” file and could ruin programs in your computer.
Is there truth to this?
Program error
G Spot.exe has generated errors and will be closed by windows.
You will need to restart the program.
An error log is being created.
Read more
Guys,
please help me on this one. Sony Video Capture thinks that the application is used by another user, or another application. That’s why it keeps on saying “The device USB2.0 Grabber could not be opened”.
Any idea how to get past this?
Sony video capture
The device ‘USB2.0 Grabber’ could not be opened.
Please make sure that it is turned on and is not being used by another application or user.
Read more
Hi guys,
I am receiving an “Unhandled exception…” error every time I load a “.mts” into TsRemux. What do you think are causing this? Any suggestion?
Thank you and I’d appreciate a response.
TsRemux v.0.0.21.2
Unhandled exception has occurred in your application. If you click continue, the application will ignore this error and attempt to continue. If you click Quit, the application will close immediately.
Read more
Hi all,
I use MkvToMp4 to convert my audio files into mp4 format. However, it just crashes and I receive an pop-up window saying it has stopped working (see image).
Does this has something to do with the compatibility with Windows 7 and Vista?
Please help me get a fix on this one.
MkvToMp4.exe
MkvToMp4.exe has stopped working
Windows can check online for a solution to the problem.
Read more
I use VOB2MPG for DVDs. When I tried to burn one I received this error (please see image).
Why does the window message mean, especially on the part when it says “the other memory is corrupt”?
How do I fix this?
Any reply would be appreciated.
Thank you.
VOB2MPG – DVD Player
Could not get interfaces
Attempted to read or write protected memory. This is often an indication that other memory is corrupt.
Read more
