Archive
I have installed MS Office 2010 on my computer and I created a table design on Excel 2010 but now I am unable to open it in Excel. The file is native to SW2011 and Excel 2010. I am using Windows 7 SP2. I extremely need your help.
Suggest me properly.
Thanks for everything.
Error Image:
Design table was created in Excel 2010 and cannot be opened in Excel 2010.
Error Message:
SolidWorks
Read more
I have a problem when doing a new fixlet for Office 2010 installation using the software distribution wizard.
After doing all the steps and it is time for the upload of software it fails within 15 seconds with an error "Problem occurred when uploading" "file name and path" "Error: HTTP Error 56: Failure when receiving data from the peer". This is only happening on remote console whether the files are locally on the PC or on a file share, when I try it from the server it works without a problem.
The folder that I am trying to upload is 2.6...
Read more
In other day, I received the following error message while attempting to activate Office 2010 and found that the machine failed to activate.
How can I fix this problem immediately?
Has an ideal to resolve this error?
Provide a best solution. Thanks in advance.
Error Image:
An unspecified error has occurred. Your request cannot be processed at this time. Please try again later. ( 0x8007000D )
Error Message:
Microsoft Word
Read more
Hi experts,
Recently, I installed ASAP Utilities on my system along with Excel 2007/2010.
Now I receive the following error message when I start Excel. The workbook has lost ActiveX controls, VBA project and other features related to programming.
I really need assistance to fix this problem as soon as possible. Suggest me properly.
Thanks in advance.
Error Image:
Error Message: Excel was able to open the file by repairing or removing the unreadable content. This workbook has lost its VBA project, ActiveX controls and any other programmability related features.
Error Message:
Repair to 'ASAP Utilities.xla'
Excel was able to open the file by repairing...
Read more
Yesterday, I was trying to change my view from standard view to Datasheet view while working with SharePoint 2010 but I received the following error message.
I searched for the solution but could not find any resolution.
I need your help to fix this issue as soon as possible.
Thanks for any assistance.
Error Image:
Web browser does not support ActiveX controls. - A component is not properly configured for 32-bit or 64-bit support.
Error Message:
Message from webpage
The list cannot be displayed in Datasheet view for one or more of the following reasons:
  • A datasheet component compatible with Microsoft SharePoint Foundation is not...
    Read more
I upgraded Office desktop version to Office 2010 and the user often tries to add new documents into a document library running on MOSS.
The error message displays when a user tries to open Word 2010 “This file could not be found”.
I want resolution related to this issue. Any help would be greatly appreciated.
Thanks in advance.
Error Image:
Error Message This file could not be found.
Error Message:
Microsoft Word
Read more
I received the following error message while attempting to run templates acquired through an internet source running Office 2010 on my computer.
The error displayed saying "Could not open macro storage".
How can I resolve this problem?
I need an expert’s advice as soon as possible.
Thanks for help.
Error Image:
Error during report generation Could not open macro storage
Error Message:
Error During Report Generation
Could not open macro storage.
Read more
I currently installed Office 2010 with AutoCAD but when I attempted to install Office 2010, the VBA enabler stopped functioning in AutoCAD 2011. The error displayed showing “AutoCAD VBA is not currently installed”.
I have tried to uninstall and reinstall the VBA enabler but the same problem appeared. I am using Windows 7 Operating System x64 with AutoCAD 2011 and MS Office 2010 x86.
I want some suggestion. Thanks in advance.
Error Image:
Error Message: AutoCAD VBA is not currently installed. Please run the AutoCAD R2010 installer to install the AutoCAD VBA component.
Error Message:
AutoCAD
AutoCAD VBA is not currently installed. Please...
Read more
I often get this error message while I assigned some values to integer in VB.NET.
I can’t understand this error and why did appear?
Can I get some resolution and instructions related to this error?
I would be grateful to you if received any suggestion.
Thanks in advance.
Error Code Description FFFFFFFF Arithmetic operation resulted in an overflow
Fingerprint Software
Arithmetic operation resulted in an overflow.
Details
Read more
I am using Windows XP OS Sp2 and got an error message when I attempted to start Hyper-V virtual machine.
The error displayed showing “’Lab-SharePoint’ could not initialize”.
I checked the memory is enough to start this app but I am unable to start the virtual machine.
Please provide some resolution to fix this problem as soon as possible.
Thanks for any help.
An error occurred while attempting to start the selected virtual machine(s)
Hyper-V Manager
‘Lab-SharePoint’ could not initialize.
Not enough memory in the system to start the virtual machine
Lab-SharePoint
Read more
