Archive
Hello friends,
I think there is a problem with the Windows 8 operating system. I tried to update antivirus Microsoft security essential I ended up in vein. There is a peculiar problem; I used to do it just like that. Today I discovered the same error message is for iTunes update too. Something is terribly wrong in my system. Urgent help please.
The installation failed.
The Installer encountered an error that caused the installation to fail. Contact the software manufacturer for assistance.
Read moreHello,
I installed new web browser chrome in my system yesterday without any issues. I am able to use it successfully; I loved the speed and protection. But the problem is, today I tried Internet explorer which is already in my system. When I startup it shows an unknown error, don’t know the exact reason behind this. Chrome created any problem? Not able to guess? Please guide me.
Unknown error.
Read moreHello Troubleshooters,
I am not a constant user of computer, don’t have much knowledge. When I try to burn the video files using Nero video in my system, got an error message. But I have sufficient space in the memory and also I cleaned the temp files thinking this might help. No luck still I am inside the problem. Help needed.
There in not enough space available for the recording process: There are 3128MB available for temporary files in the folder ‘C:UsersBaniAppDataLocaltemp’, but the recording process will need approximately 4568 MB.
Read moreHello,
Dropbox Installation went pretty well, but when I start the program getting an error message. For first time I did not choose the location it did in default download folder. After this error I tried to store it in proper location, but still the problem exists. How to install it correctly? Am I doing any mistake? Please explain friends.
Dropbox is running from an unsupported location.
Please visit https://www.dropbox.com/install to download and install the latest vertion.
Read moreHi ally,
I give a try to setup my desktop without any help from hardware persons. It went good to some extent, setting and connecting is ok. I am able to boot my system and also getting an error saying processor is not supported. So did I make any mistake in installation? Are any errors in driver installation? Totally screwed, help needed.
The processor detected is not supported.
AMD Phenom™ II X6 1090T Processor.
Read moreHello,
I installed the UpdateWizard in my system long back, may be 4 or 5 months. So when I try to run this program from startup, I could not do. And it is showing me a message. So I rechecked the name and typed again but no result. How will I find out the program is still in my system? Help me to find it.
Windows cannot find ‘C:Program files (x86)TuneUp Utilities 2014UpdateWizard.exe’. Make sure you typed the word correctly, and then try again.
Read moreHi Whiz,
I am freelance using skype to some extent to keep in contact with client. For past two days I am in trouble. Whenever I open the skype, runtime error is occurring and it instructs me click either yes or no. But not able to do anything, even I am not able to close the program. System task manager helps me to close the program. Whizzes why I am getting this error? How to solve this? Help please.
A Runtime Error has occurred. Do you wish to Debug?
Line: 52
Error: Object required
Read moreHello Guys,
I have a two Dell laptops, one with nVidia GeForce GT540M and the other with an nVidia GeForce GT550M cardworking with the integrated Intel (R) HD Graphics. I have a trial version of Autodesk Civil 3D 2014 installed on Windows 7 x64. When I ran the program for the first time, it asked me for a license and when I provided the same, it tries to check something and then stops and pops a box saying "Autodesk component has stopped working". I have earlier version already on my computer and want to evaluate this version. Can anyone tell...
Read moreHello all,
I was using the pretty old version of sharepoint for long time, without any issues. But now things changed, it asked to me update the version so. After updating I am getting this error message. What will I do now? Some documents are created in old version and some in new, how will I correct this problem?
Sorry, Word Web App ran into a problem opening this PDF. To view this PDF please open it in Microsoft Word.
Read moreHi there,
I have Asus Nexus 7 Tablet, when I connect my device with my Dell Latitude Laptop running on windows 8.1 the Tablet is not recognized and it is not charging at all, when I switch it off and connect it, it is recognized as a USB device and it starts to charge, what could be the problem? How do I get this Tablet working well?
Read more
