Archive
Anyone tell me how can I change the category order in WordPress.
I create some categories and after that I create some posts, but those posts don't appear according to my wish I want change order please anyone tell me its solution.
Read more
How do you set up a proxy server in Windows Server 2008? We need it to monitor employees. Any recommendations on the settings?
Thanks a lot.
How do you put a dstname field into the syslog in Sonicwall Pro 3040? I want this field to contain the URL input by the user for tracking.
Read moreUsers cannot access the SFTP command in Qshell iseries mode. Only a few are able to access. What’s wrong?
Thanks in advance for the help
Read moreOur McAfee 8.7.1 updates manually but does not update on its schedule. Can anyone help? Most web traffic is allowed on our proxy server.
Read moreWhat does the Windows Firewall do and how do I enable or disable it? Is it possible to add an exception so it will prompt the user for request?
Read more
I have a Windows 2003 server and iSCSI target server both in the same host.
Does the traffic in iSCSI between VMWare users stay within or does it go somewhere and then go back in?
Read moreIs there a way to see which users have associated CA certificates?
Can anyone recommend which API to use for v5r4?
Read moreMy MS Office trial has expired and now needs a product key. I just bought a copy. Do I need to remove the trial version or do I just enter the key?
Read moreHi experts!
I am curious to know how long would a defragmentation take when you do it for the first time?
When I did it on my computer, it still did not finish after 12 hours.
And after I did it, I lost computer space. Did I do something wrong?
What should I do?
Read more
