Archive
I have Windows 7 MCE system with Ceton InfiniTV and TMT5 for Blu-Ray. I am facing some problem with the recording. It is getting stopped randomly. No other tuner applications are installed. That’s why I done know any other service will solve this problem. It is not happening because of manual intervention. Please help me to fix the problem. I will thankful for all help and support.
Read moreI am facing some problems with 7 MC Rig. I want to do scorch earth reload. If anybody knows to fix this, please help me. The Seven MC setup gives me error message ‘no audio device found’. But, after the restart it is working properly. The latest ATI driver and Ceton firware drivers is already installed. Please help to figure out this problem. Thanks in advance.
Read moreI installed HP Remote Support Software Manager and when I try to launch it, I received an error which states the country/region is not set. I already selected the correct country from the drop down list, but still get the same message. How can I configure it without errors?
ERROR: Your country/region is not set. You must configure Remote Support Software Manager before you can use the product. Please perform configuration using the RSSWM configuration shortcut (typically “All Programs –HEWLETT-Packard-Remote Support Software Manager – Configure Remote Support Software Manager”). Exiting the...
Read moreI am looking for help to renew SSL certificate. It is to be done from Company’s Server which is Windows 2003 CA. The certificate is expired and the internal web server runs with HTTPS. Please guide me to the proper way. I think it is to be done through Cat’s website. If anybody knows how to fix this problem, please let me know. I will thankful for all help and support.
Read moreI am looking for some help to install Oracle Web Logic server 11 G. I am getting an error message when executing the Web Logic Server. The error message says that ‘it is not able to archive because it is corrupted. Please help me to get out of this problem. Thanks in advance.
Read moreI have been doing hardware sizing for web logic server from SOA suite and AIA.
There are a lot of environments are using.
Please suggest me the required RAM & Disk size and CPU.
I will thankful for all help and suggestions.
Read moreI just upgraded my OS to Windows 7. I lost all the software and drivers so I have to re-install everything including Autodesk 3ds Max 2011. The problem is after re-installing, the Autodesk 3ds Max 2011 in Start menu was changed into “Change Graphical Settings”.
When I double-click to open it, the program will start to load and will last for few minutes and ends up with a pop up error as posted below. I uninstalled the software and try to re-install back but still get the same problem.
What can I do with it?
Autodesk 3ds...
Read moreAn error message is getting when I am trying to start the service from the COGNOS server. I have searched in forum but nothing found helpful. Please see the error message. ‘Event ID description is not able to find. May be the installation is corrupted. Repair the component in local computer. It runs with Windows Server 2008. I don’t what is happening. If anybody knows how to fix this problem, please let me know. I will thankful for all help and support.
Read moreI am using Soft share in virtual server which runs with Windows Server 2003 and have 8 GB RAM. The server performance is very slow. I have opened the task manager and it is showing whole CPU time is hogging by the task manager. But it is not getting fast when I close the task manager. Is it possible to view the actual CPU usage? If anybody knows why it is working slow, please let me know. I will thankful for all help and support.
Read moreWe are having two SQL database sized 1.5 GB and 6 GB in a server.
New transactions are added on a daily basis.
We want to backup the database to a remote location on every day.
It is not possible to back up the full 6 GB database on every day.
So, we need to backup the present day transaction on every day.
Please give me some suggestions.
Read more
