Archive
Hello experts,
My problem is that when the computer boots up to the login screen, I get an error message.
I don’t have any idea why I would receive this message.
Hope someone can shed some light to this.
Here is a screenshot of the dialog box:
I got an error on installing my scanner. It stating "Windows found the driver software for your device but encountered an error while attempting to install it. Epson Perfection V700/V750 Not enough storage is available to process this command". Any fix?
Read moreI am having a hard time syncing my iPhone 4 with MS Outlook. Can someone provide a procedure for this?
Read moreHi.
I just want to know how I can import my contacts from my old Blackberry contacts to my new Samsung Galaxy SII?
Read moreHello there, everyone!
While I was playing, my malware popped up saying there’s a malicious software in the LoL files so I removed them. But now when I try to open the LoL launcher, it creates a RADS Error that says: “Cannot Connect to the HTTP Servers”.
It also says that I have to check my internet connection and/or firewall. I don’t think these cause the problem in any way because the settings look okay.
I tried to reinstall the program countless times and I even followed the suggestions I read from the help forums but I had no satisfactory results.
Please help...
Read moreAn unknown error has occurred. It displays the following:
Server: 'smtp.talktalk.net'
Windows Live Mail Error ID: 0x80070057
Protocol: SMTP
Port: 25
Secure(SSL): No
This message has been appearing since last Wednesday while I was using Windows Live Mail on Windows 7. I ran a virus scan last Tuesday night and on Wednesday, my email failed respond properly anymore. I can’t send anything but I am able to receive emails. I've tried to type in the email address manually and I was able to send one email but after that, it stopped working again.
So how can I get rid of this problem? Thanks for...
Read moreHello experts.
When I try to use SSH by the control panel and even through SSH Terminal emulation program, I always receive the following error message. See below:
I have already unchecked the SSH choices under SSH. Now I need your help. Thanks in advance.
Error:
Connection Error Could not establish a connection to host:
Connection reset
Read moreHi experts.
I am getting serious troubles when I try to use Lync 2010 (https://www.microsoft.com/en-in/download/details.aspx?id=28177) from the OP+ edition to O365 edition.
Really, I am upset and depressed. I'm using the trial version of O365. If I am able to use Lync successfully, I would buy this software.
I have installed it a couple of times on my system, but it is still not running. I've searched the forums in this website and even looked on other sites. Then, I uninstalled and reinstalled it.
Still, I am getting the following error message:
Need to solve this. Thanks in advance.
Error:
Lync
Cannot...
Read moreHi.
This concerns the software named Solidworks. I tried to click on an element in the tree and after that clicked the right-mouse button (RMB) on a dimension as well as selected "Configure Dimension". After that, I got the following error message:
Solid Works
The properties.txt file cannot be located at the specified location
C:Documents and SettingsAll UsersApplication DataSolidWorksSolidWorks 2008langenglish;.The SolidWorks software will use the properties.txt file located at <install_dir>langenglish.
OK
Please give me a solution. Thanks a lot.
Read moreHow can i be able to make myself fit to get feedback from the employer in to Odesk job program.
Read more
