Archive
I am trying to go to MediaFire with Google Search, but I am always redirected to an error page as shown below.
It says
The indexed link is unavailable. The link was indexed is currently set to a non-indexing state and cannot be accessed.
If you believe that you have reached this page in error, please contact support.
Click here to view our help resources.
What is causing this?
I cleared my history and all, but it shows no effect.
Please help.
Read more
I just got my new Windows 7 64-bit PC with pre-loaded iTunes. But when trying to connect my iTouch Generation 2 to iTunes, it won’ work. And today, I just got an “Error 0xE8000065 cannot recognize the iPhone”. And this also occurs when connecting my iPad 2. This is working on my previous Windows XP OS. Please help.
Read more
how to install Remote Desktop in windows XP?
It can use computer to Computer remote Desktop share
Read more
I am facing an error when launching MS Word. It failed and crashed with error
“Library not loaded: @rpath/mbukernel.framework/Versions/14/mbukernel
Referenced from: /Applications/Microsoft Word.app/Contents/MacOS/Microsoft Word
Reason: image not found.”
I tried to remove the suite and re-install it back but it did not help me resolve the issue. Please help me.
Read more
I am making changes on my Photoshop and close it afterwards. When trying to open it again, I am now facing an error
Could not open a scratch file because the file is locked or you do not have the necessary access privileges.
Use the ‘Properties’ command in the Windows Explorer to unlock the file.
I tried to start the Photoshop again and click on ‘Yes’ when asked if I want to ‘Delete the Photoshop settings file’, but it did not help.
Any other fix that you could recommend?
Read more
I have downloaded and installed Acronis True Image Home 2012 trial but I found out that it uninstalled my True Image Home 2010. When trying to install it again, I received an error "E000101F4: Application module error. Cannot find the necessary Acronis True Image Home modules. Please reinstall Acronis True Image Home." I tried again for few times more but failed.
Any suggestions on resolving this error?
Read more
I once tried to set up Norton Partition Magic during my PC . After I tally the program I'm acquiring this error message:
"Init Failed: Error 117"
"Partitions Drive Letter Cannot is identified"
So when I press "All right" the program exits. However, I am capable to partition utilizing "Acronis Partition Magic". However, many other partition software system likewise deliver some mistake communication along with depart.
I attempted "PARTINFO" software and yes it revealed "Disk Problem, Computer Geometry Miscalculation, along with Division Blunder".
How can I clear up this challenge?
At a website somebody gave me a remedy in which, primary turn off...
Read more
My own brother and his girl have difficulties with this computer system and I am also trying to assist them. The system is just a workweek aged and he or she has an issue with Home Windows. Every time she attempts to begin in place anything, my spouse and i.e. Outlook, MSN Messenger and many others error messages appear. She will mail the error report to Microsoft but that is it. Nothing else may be powered by the woman PC without a problem message showing up.
Are there any suggestions on how we can stop this error from coming? She got onto the actual windows Update...
Read more
Why does it happen that immediately after starting up Console One error appears?
I bought this blunder 0x8884 Switched Electronic Routine failed whenever simply clicking the tree diagram.
Are you aware of it? If it is some sort of protection under the law dilemma?
Pleases assist. Thank you.
Read more
I'm having a challenge with VBScript; I don't know when it is a virus or simply the reg. error.
After I tried to uninstall it, I still get the problem and it will definitely not uninstall. I will be using it to create planned projects.
Many thanks on any kind of help.
Read more
