Archive
Hi ,
Is it possible to keep Infrastructure master and global catalog in one domain controller or in multiple domain forest?
If not please explain .Its important for me to know.
Thank you.
Read moreHi ,
We have a database on DB-01 that is running an instance SQL server 2005.
Recently we faced a power outage and it forces to restart the DB-01 which now fails to start SQL server.
How can we restart it.
Please help.
Read moreCan anyone write me spiral code for java using recursion? I don't understand this.. please help
Read more
Hey guys. My OS is Windows XP and I would like to ask which is the best backup software to use. I am looking for a free backup program. I read some reviews but I would like to hear some opinions. I currently use Windows Live Mesh, but I would like to know if there're better solutions. Thanks.
Read moreHi,
I my network We are using esx 4.0 for virtualization.We have a windows VM.Widows guests fails with:STOP 0X77 KERNAL_STACK_INPAGE_ERROR.Please help me.
Read more
what programming language should i learn first, i don't have any prior programming knowledge at all. I was told to start with HTML, but i heard elsewhere that HTML is quite slow and time taking. I don't know if it is true or not, but what is your opinion?
Read moreWhen you run a C++ program, what will appear on the screen after following statements are executed?
int a=0,i=0;
while(a<=10){ a=a+i i=i+2; }
cout<<a<<endl;
The answer should be 30 but how come?
Read moreHi have a database. But I have a bug which updates the POS terminal but doesn't update the main database. I have searched all the link connections in the system. Can't identify it? IF you want, I'll attach a system organization chart. |
Read more
I'm using my Android, Samsung phone as a WiFi hotspot. I have made public my WiFi connection.
Is it possible for someone to put a virus to the entire WiFi system?
Read moreI have an external storage medium, a USB hard, containing viruses originating from my Windows box. If I plug it into my Linux box, what will happen? What if I use Wine?
Read more
