Archive
For the very first time the Bluetooth of my Dell laptop worked properly.
But after reinstallation of windows, now the Bluetooth can't find any devices nearby its coverage area.
I have tried this process more than 25 times but always it shows 'failed to connect'.
Please suggest to solve this problem.
Read more
I use a NOKIA c5-03. Suddenly in the LCD there appeared a black spot. Which is not water. I used a hot gun to flash them away but didn't work. Why is this?
Read more
I connect to internet through Nokia browser.
How to open something which has been already downloaded?
Read more
I know this is a pretty simple question.
But i don't know the difference between IM and PM in chat.
What are they?
Read more
I use a PDA to store as my backup. i displays a message "Please plug into the charger" but shouldn't it be charging while connected the PC through USB
Read more
I hear radio advertisements playing in the background of my PC.
Can't see an application as well.
How to remove this?
Read more
I normally store data in a remote server. All the machines in our office do. But today when I go to my server and check, none of the documents were there. But when I check from my machine, I see the files. Why does this happen? need a quick solution.
Read more
I installed Error tech software and now I can't uninstall it.
I went to control panel to uninstall it. But then It doesn't show any software like that but the start bar shows.
Read more
I updated the system and switched off but when I restart it, I can't run any of the .exe files.
When I double click it just doesn't run it.
Read more
Could you please explain what svchost.exe trojan is? Is it harmful or just a not problem thing?
Read more
