Archive
Hello people,
I use a VirtualBox to run multiple operating systems on my computer as I don’t have to reboot each time I change the operating system. But when I installed Fedora16 and executed it through VirtualBox, it starts the operating system but GNOME fails to load and I get the following error message:
Hello!
I am currently developing a web based application and I tried to integrate virtual earth services in it.
But when clicked 3D on the installer the setup starts installing it and suddenly it pops out the following error message:
Error:
Virtual Earth 3D Installer
I have installed Joomla version 1.5 on my system and it went fine to the point of creating sample data. I am running this on Windows XP. Please have a look at the error and tell me the solution. Appreciate your help. Regards.
Error:
Error: the XML response that was returned from the server cannot be processed.
Read more
I have recently installed Linux and for this I need apple safari browser. But first I must know whether apple safari software will run on Linux or there is different version of safari available for Linux. I need the answer quickly so please someone help me solving this problem.
Angelo Brent
Read moreHi,
Whenever I run a user-built distribution, I receive the following error displayed below.
What do you think is causing this error?
Please help.
“The NI IVI Engine installation has failed with the following error.
A higher version of the product is already installed on the system.
Continue?”
I need some help regarding .net installation. I installed .net framework but right after installation I failed to login my Windows Vista OS. I have not saved a restore point to restore my operating system.
I have tried to repair it with my DVD but to no avail.
I have tried again to install it, but this message has been displayed.
Thanks for your help.
Error:
An error occurred during setup. Installed files have been removed from your computer. For known issues and troubleshooting information, see the online Readme . For error information, see Error Log.
Read moreHello,
I was using Linux operating system and recently I changed it with windows 7. I had a set of software for Linux and I did not know there would be any trouble. I tried to install them but they are not working on windows 7. The problem is slowing my work down. If this problem does not fix than I have manage a new set of software which will be trouble. Please, if there is a way to use Linux softwares on windows 7 kindly tell me what to do.
Mickey Nixon
Read moreHi,
I want to install SP2010. The installation of the prerequisites went fine but later when I tried to configure the product SharePoint at step 8 of the process, the following error message was displayed.
Please help.
SharePoint Products Configuration Wizard
