Archive
What is the advantage of using memristor (technology invented by HP) on manufacturing of hard disk?
Will it be cheaper than the current technology?
Read moreWhen I type #dmesg | grep eth there is no eth network interface, and here is the result:
[ 34.763244] Driver 'sd' needs updating - please use bus_type methods
[ 34.763332] sda:<4>Driver 'sr' needs updating - please use bus_type methods
I just want to adjust the IP, but there is no interface network.
Please help.
Read moreI Installed mail server zimbra on Ubuntu 10.04. It run perfectly.
But the problem is my Zimbra can't receive and send email except emails from the database.
Is there any configuration so I can send and receive email from all?
How the quality of Internet connection depends on CINR and RSSI values?
What is the minimum value of these two to use a 1 Mbps internet connection?
Read moreI am an CentOS user.
When I type an command on terminal window and press [ENTER] to run command, it keep open new tab.
Here is the screenshot:
[root@localhost ] # su -l Ajibdah~
[root@localhost ] #
So it keep open new tab every time I press ENTER. But doesn't run the command. :(
Read moreI have run into a problem with my web camera. Upon starting a video call, the camera quality is very good, but it suddenly turns entirely to shades of green with many distortions. It only happens about 25% of the time, but this problem started after I redownloaded the driver. Since it's not constant, is the problem more likely a hardware issue starting to act up, or is it possibly the driver causing the trouble?
Specification:
hp60-458DX
Internal Camera: HP Webcam-101
Driver 6.0.6001.18000
Many Thanks!
Read moreNeed help from experts! When I plugged the headset on my laptop, I couldn't hear any sound. I have tried with another headset, but nothing changed. I'm sure all the headset work well. And I still hear the sound last week.
Read moreUsually I would have some problems regarding my laptop, being a regular guy I seek help from IT sites. Then I came across http://www.rightc.co.za/index.php/en/forum.html and there I got the answers to my problems. All technological knowledge you would find there.
Read moreHi, my HP Pavilion DV6000 series laptop overheated and damaged the graphics card. The tech says that it is probably not worth repairing the laptop as the card itself costs around $300 plus the labor. He also said that the card is part of the motherboard, so I'd have to replace the motherboard as well.
In addition to the cost, he said that this laptop series has inherent serious problems with overheating.
So, in his opinion, the new card could get fried in the following six month after the install.
Has anybody else tried fixing their overheated HP Pavilion DV6000 series with...
Read moreI have laptop in On condition but the motherboard doesn't appear on monitor screen.
- LED Power is On
- No beep
- Keyboard lamp is normal
-I have changed the power supply, RAM, VGA, processor, battery cmos and clear cmos but nothing changed.
Please, solve my problem.
Read more
