Archive
Not a valid Win32 application. This error will be related to the following error message. C:Program Filesmyprogramprogram.exe is not a valid Win32 application Need your help to solve this error. Need a solution for my Win XP PC.
Thanks a lot.
Read more
Easy Way to Learn About Computers? Learning about computers is easier nowadays. It does not have to cost you too much especially if you do self-study. The internet offers tons of information on how you can learn about computers.
Read more
I have upgraded my PC with spec:
Core i7 2600k
GA z68ma D2h B3
Ram Corsair 8gb
PSU superflower 550
VGA MSI nx8800GTS
Hard disk Seagate 250 GB
I arranged them alone, successfully installed windows 7, Mabo, VGA etc. And suddenly my VGA became artifact.
Was my VGA damaged?
Or I arranged it in wrong place?
Read more
I need your opinion about HSF, I have enough budget for Cooler Master Hyper 212+ or Deepcool Ice Blade GS.
Which one has better performance?
Or is there any better option with same range budget?
Read more
I have LG-1717s LCD monitor, I couldn't replace its bracket, I tried to pull and make it move, and I have opened all bolts.
Unfortunately,I lost the manual book.
Here is the picture:
Thanks for help.
Read more
Need Suggestion. Which one is better? Android OS or Windows 7 OS?
I want to buy pick out one of them. (Android tablet with 1.4 GHz Speed, Win7 tablet with 1,66 GHz).
Thanks!
Read more
What is the difference between capacitive and resistive touch and which one is better?
How the touch sensitivity is determined on a touch screen device?
Read more
Here is my PC specs:
Procie : intel core i3 2100
mobo : ASRock H61M-HVS
RAM : PATRIOT PSD3 8G 1333 KH (2x4Gb) DDR3
VGA : Digital Alliance GTX 550 Ti
Does it fit if I use PSU ENERMAX NAXN 550W?
Read more
I can not find the drawing control in the COM Components tab, as a result it is not possible for me to add the drawing control to a windows form application. How can I solve this issue?
Read more
I make a simulation using IDE NETBEANS but there is a warning: Exception in thread "AWT-EventQueue-0" java.lang.NullPointerException
on source code :
if(!mapRouter.containsKey(routerA))
addRouter(routerA);
Anybody know how to finish it?
Read more
