Archive
I am having trouble launching Digidesign Pro Tools. I have received the following error that says, “Warning: Loss of Plug-In authorization keys may occur”.
Any idea why I'm getting this message?
Thanks!
Warning
Loss of Plug-In authorization keys may occur.
This system contains one or more drive(s) formatted with NTFS, which have volume names longer than 11 characters. This combination is known to corrupt some InterLok Plug-In authorizations. If you know which drives are authorized and they are not configured this way, or if you have no InterLok protected Plug-Ins, then you...
My laptop can't write flash disk, USB modem, etc. It has 3 ports.
Firstly, it's just one port that doesn't work, then followed by two other ports.
And now all Ports don't work at all. If its ports are damaged, can they be repaired?
Read moreHow can i create password in my usb port in my PC . I use windows 7.
Read moreHow can i create password in copy, paste & delete function in windows 7?
Because my friends use my PC ©, paste & delete my file.
Please help me.
Read moreHello guys, I use Autodesk 3Ds Max for a very long time now. But after upgrading my computer to Microsoft Windows 7, may be it is because of some virus infection but I am not sure, I don’t see the shortcut icon to autodesk 3ds Max in my start menu and when I open the application I keep on waiting and all I see is the progress bar running and running.
After some time I get this error saying that “Software Licence Checkout Failed: Error 20” and the application just closes. I tried to uninstall it from my computer and...
Read moreHello, I am facing some problems installing VMware vsphere client on Windows Server 2008. And I am getting this error while installing: "Error 1406 - could not write value Product Language to key SOFTWAREVMWARE, Inc. VMware Virtual Infrastructure Client. Verify that you have sufficient access to that key, or contact your support personnel." Please tell me if there is a way to install this or why I am facing this problem.
I wanted to install Microsoft Office for Mac OS X Lion but when I tried to install it I received this error:
Software Requirement
This software requires an Intel-based Macintosh computer.
Is there any way to install this on my mac?
Read moreI am a Microsoft windows user.
So I am well aware of a system file with name rundll32.exe, there are a lots of errors because of this file (maybe) but this time I am getting an error in rundll32.exe.
Whenever I shut down my computer or even when my computer starts up I see this error during the startup process which says:
Runtime Error!
Program: C:WindowsSystemrundll32exe
This application has requested the Runtime to terminate it in an unusual way
Please contact the application’s support team for more information.
OK
I have a problem with skype plugin on Google chrome, from time to time a notification comes out saying that a problem with skype plugin has occurred , notification asks if I should stop it or not. What should I do?
Read moreHello everyone, please help me resolve this problem. I recently subscribed to and downloaded the installer for Blackthorne Pro but it is not installing it on my computer and I get an error saying:
Error 2738.Could not access VBScript run time for custom action.
What could be a reason for this?
