Archive
I am using Citrix Password Manager, but it fails to perform the automatic key recovery feature if the User Id is changed in the active directory. And it closes after giving an error which says
The Password Manager Service Key Management Module could not locate your keys.
I have attached the screen image showing this error.
One possible reason could be that the User ID is used when the software encrypts or decrypts the data, and it can only be accessed by the password confirming the user’s identity. And when we change the user id after encrypting, it fails to decrypt.
I am...
Read moreHello guys, I have an issue while logging in to Microsoft Dynamics CRM 4.0.
Whenever I try to login, I get an error saying
INVALID ACTION
The selected action was not valid.
One of my friends has also asked me for help regarding this same issue, but I have no ideas.
He is facing this problem in his office where Microsoft CRM does not allow any of their users to log in. Even the administrator’s account is not able to login.
Any help would be greatly appreciated.
I have attached the screen shot for this:
I am trying to install AdCenter SQL 2008 Express R2 edition and I am constantly receiving error messages.
I have been trying to install AdCenter for quite some time while running Windows XP service pack 3. The installer installs most of the software but then an error message occurs stating that installation could not be completed, but then it still installs AdCenter. Everything goes well until I run AdCenter and get the following error that I am attaching here.
I have tried to install it using my own executable installer, but it has not helped either.
I have removed and reinstalled the...
Read moreHello,
I am having a problem with GroupWise 8 client.
When I attempt to ‘trust’ a received digital certificate from an email, I get an error. I am using the following system:
Microsoft Windows XP
Novell GroupWise 8.0 SP1 Hot Patch 1
Novell GroupWise 8.0.1 HP1 Client for Windows
Every time I try to trust the certificate of the sender by clicking the red warning button or by toggling File > Security > Properties, I receive an error.
I have attached a screen shot to help you guide me.
Thanks a lot.
Update Trust Error
Unable to show modified trust information!
Read moreI have received this error with Norton Ghost and I’m not sure what to do with it:
Error E7D1001D: Unable to open //./SymantecSnapshot0/encrypt/<Filename>" in BESR
Problem
A Symantec Backup Exec System Recovery (BESR) backup job of an encrypted file with file and folder backup fails with the error "Error E7D1001D: Unable to open //./SymantecSnapshot0/encrypt/
Error
Have any ideas on this? Thanks in advance.
Hello.
Every time I try to connect with the version 7.10.500 of the ICA Client for Macintosh, the following error arises
Cannot find encryption module “EncRC5”. Session will be unencrypted.
Error Number: 8
What could be causing this? I have attached a screen shot too.
Please help.
Thanks a lot.
I have installed flypaper on my Windows XP SP2 and after I restarted the system and ran the program, a screen appeared with the ‘checking for updates’ message. After some time, the screen went blank and then I got the following error message, “sqlceexception” that says that the operating system does not support encryption. I have tried uninstalling and reinstalling the system twice, but no help yet. I have attached a screen shot below. Thanks.
Hi. I have recently installed PCTV PRO Hybrid USB Stick 340e, but when I run it the following message is displayed every time.
Any help would be great.
Thanks a lot!
Error:
Pinnacle TVCenter Pro
Unhandled exception has occurred in a component in your application. If you click Continue, the application will ignore this error and attempt to continue.
Parameter is not valid.
*************** JIT Debugging ***************
To enable just-in time (JIT) debugging the config file for this application or computer (machine.config) must have the it Debugging value set in the system windows forms section. The application must also be compiled...
Hey. I need a solution to frequent Pro/E Crashes. While working on assemblies or switching between a few open parts, I often receive this message.
The assemblies I am working on are not very large, but still this issue is arising very frequently. Can anyone help me with this problem with pro/engineer and tell me the reasons for this behavior? I am running WF5. Thanks in advance.
Auto-traceback Info Pro/ENGINEER has encountered a problem and will exit. Select OK to generate a traceback file for Technical Support, or Cancel to exit. |
Read more
I am having a problem with my Robot Pro 2011. I am trying to install the extension for robot (robotextensions2011.exe - 212Mb). The setup gives me the following error: “robotextensions2011.exe - 212Mb”.
What could be causing this? More importantly, how can this be fixed?
Thanks in advance.
Robot Extensions for Autodesk Robot Structural Analysis 2011
Robot Structural Analysis 2011 or Robot Structural Analysis Professional 2011 is not installed on this computer!
Please install one of those programs first.
