Archive
Hello community,
I have setup six computers for LAN network.
The problem that I am facing is all six computers are not able to share files at the same time.
Out of six computers only four computers are able to access each other, while the rest two have a problem accessing the network.
What could be the problem?
Read moreWhen I start PageMaker 6.5 the system shows the following message. Unable to load icon.dll and gives the page fault error. But if I start the system in safe mode, the program works fine. How can I resolve this?
Read more
A few days ago we had a power failure. After this, Windows asked me if I wanted to prevent it from going into standby in future. I clicked, yes. Everything works fine now, except that I can’t find standby. I tried going to Control panel > Advance but there is no option to restore my standby
Read more
Whenever I start my computer, it gives me an error message indicating that the files are missing. These files are ‘vnetsup.vxd’ and ‘dfs.vxd’. Please tell me what should I do
Read more
My hard disk has three partitions with drive letters C and D used by Windows 98. The third partition is used by Linux. Why can’t I view this partition in Windows Explorer? Also, how can I uninstall Linux?
Read moreI am using Windows 7 and Laser Jet printer P2014 which saves multiple print commands.
However, the commands cannot be remove from the printing command queue.
It continues even after switching of the printer and turning it on.
The same problem does not occur while using my laptop with Windows XP.
Read more
I keep getting an error message say” run DLL as an App failed” when I try to open the desktop tab in my display properties. I am unable to change any of my desktop items dues to this
Read more
Whenever I try to run Nero Burning ROM (any version) it shows up a message at the startup stating that “the Nero executable had been corrupted and the program cannot be started”. Even disabling and enabling the DMA has no effect
Read more
I have a very unusual problem. My keyboard does not work in the system BIOS. It shows me the first screen of the BIOS but I am subsequently unable to use any of the keys on the keyboard. Sometimes I am even refused entry in the BIOS. After booting the systems works.
Read more
