Archive
Hello buddies,
I am running Ubuntu 11.10. And the Mozilla Firefox error shows "A plug in is needed to display this content: Adobe Flash Player Installer" So then I install it, it displays "Installed - restart Fire Fox" after that I restart Fire fox but the same error message again pops up.
I don’t found it with Windows 7 (IE, Chrome & Fire fox are fine) or with previous version of Ubuntu. Problem starts when I try to access CallOfRoma.com. Need help.
Read moreHello,
Yahoo messenger error: While trying to copy the messages which my friends sent to me on instant messenger it won’t allow me and a window just appears and says: “file:///C:/Program%20Files/Yahoo!/Messenge...do you want to continue running scripts on this page?” Nothing happened after pressing the “yes” and after that I pressed no and, as usual, nothing happened.
How can I solve this? Please help me. Thanks in advance.
Read moreHi everyone,
I want to upgrade my Virtual DJ from v.4.3 to the latest version v.5.0.
But I failed to start my Virtual DJ. Always an error message appears on the monitor. (Invalid skin file error) and that occur after trying to update the version, I want to remove the process from add as well as remove program but another message appears.
(Unable to open install. log file) Only for that message I failed to delete the program and also unable to reinstall it.
Is there anyone who can help me to solve this issue?
Read moreHello community,
When I try to open a number of .pdf via Adobe reader using command line by "acroread foo.pdf", then the following errors appears: The messenger is now down An IOException occurred at scim_bridge_client_imcontext_set_cursor_location () I found a few issues like this, but unable to solve my problem.
Can anyone help me? Thanks in advance for the reply.
Read moreHi guys,
"MSVCR80.dll is missing" Where it is (or where I can find this) & where should I put this in Windows Seven?
When I press to open PP Viewer to running Windows 7 operating system on this latest Gateway, it shows a problem.
Originally I have downloaded and setup PP Viewer since I was using Easy Worship, a process for arrangements to a project, and wanted something to bring in and run my PowerPoint files.
Thanks for reply.
Read moreHello all,
Just I have upgraded my Winamp to 5.57 trial version from their website. When I play Winamp, I have faced this error “error compiling ps_2_0 warp shader. Anyone knows how to remove this or what is it?
Read moreAs thousands have contributed code to the Linux kernel. How they combined this code to create a Linux operating system?
Recently I upgraded to the SKY X Professional version. When I try to join the CCDAP5 Software in setting up mode I am receiving the following message:
Link to software error, The SkyX Adapter.StarChart 1:COLeException Type
mismatch
(800200005) SCODE 80020005
Link to Software Error, the skyxadator.starchart.1:ColeException:Type
mismatch
(80020005)SCODE: 80020005
I am not able to fix this error message. I'd appreciate any help!
Hi everyone,
I am unable to send any mail to others. Now I am using Windows Live 2011, Incredimail and Thunderbird V3. Please see the following JPEG screenshot with the relevant information.
Can anyone help me?
Thanks in advance.
Send Message Error
Sending of message failed. The message could not be sent because connecting to SMTP server 127.0.0.1 failed. The server may be unavailable or is refusing SMTP connections.
Please verify that your SMTP server settings are correct and try again, or contact the server administrator.
Read moreHi all,
Dreamweaver MX template shows me this error "Nested editable regions" even though there are no nested editable regions and it also refuses to update the linked pages.
Please tell me what could be wrong?
Thanks for your reply
There is an error at line 4, column 138 ( absolute position 267) of ' ' ) Nested editable regions.
Read more
