Archive
I encountered this Microsoft Visual C++ Runtime Library error prompt. The program in question is the MapleStory.exe.
Runtime Error!
Program: C:Program FilesWIZETMapleStoryMapleStory.exe
This application has requested the Runtime to terminate it in an unusual way.
Please contact the application’s support team for more information.
Read more
Hi guys,
I desperately need some help on this unexpected internal error that I came across. Thanks in advance for any help.
Internal Error
An internal error occurred
exceptions.IndexError:
list index out of range
The program will try to continue but might behave in unexpected ways. Please consider restarting the
program to avoid such side effects.
To help us fixing the error in future versions relevant information including:
licensenumber: XXXX.XXXX.XXXX.XXXX
system: 5, 1, 2600, 2, 'Service Pack2'
version: 2.0
and debug info will be submitted to
http://www.atomistix.com/Errors/report_error.php
Read more
Hi experts
When I want to run a thermocouple task on a machine, such as the PXIe-4353, which utilizes a CJC channel on a new machine, I get the following error message
Error:
DAQ Assistant Error
Error -201426 occurred at DAQ Assistant
Possible Reason(s):
One or more devices do not support multidevice tasks.
Device: PXI1s1ot6
Read more
I discovered the following errors when I went to start programs then application action and then errors properties.
I hope someone could help me out here.
Read more
Hello there,
Does anyone know why a “publisher cannot be verified” by prompting out?
I hope someone could enlighten me.
internet explorer-security warning-publisher cannot be verified
Error:
The publisher could not be verified. Are you sure you want to run this software?
Publisher: Unknown Publisher
Read more
Guys need some help on this error encountered. While I was using the adjustment program for my Epson Printer, I came across this problem:
Epson Printer-adjustment program-error This Program cannot use because it expired.Delete this program and obtain a new one.
Error:
Adjustment Program
!!!ERROR!!!
Read more
In my document that I am doing right now, I am experiencing jumping text every time my mouse hovers from here to there, I get irritated with it and I want it to stop so I can proceed with my work.
So, how can I stop my document work from text jumping?
Please Answer.
Thank You.
Read more
I'm encountering this critical error while running the WOW.exe program.
I hope someone could help me out on this ‘World of War craft error’ that is being encountered.
Wow
This application has encountered a critical error:
ERROR #132 (0x85100084) Fatal Exception
Program: D:ProgrammeWorld of Warcraft 3.3.0 -2Wow.exe
Exception: 0x0000005 (ACCESS_VIOLATION) at 001B:00667667
The instruction at "0x00667667" referenced memory at "0x00000021".
The memory could not be "read".
Press OK to terminate the application.
Read more
After logging in to PCSchool, I encountered this error prompt:
Please enter a valid date prior the PCSchool does the run.
Error
Technical Details
Error Number 16
line Number 56191
Read more
Hello
When I am trying to open the Software Manager, I get nothing and it works fine. But when I want to open Package Manager I find the following
"An error occurred
The following details are provided:
E: malformed line 1 in secure list/etc/apt/spurces.list.d/ubuntu-tweak.stable.list(dist parse)
E: The list of sources could not be read.
Go to the repositories dialog to correct the problem.
E: _cache->open() failed, please report.
Read more
