Archive
Hi experts,
When I am starting the index tuning advisor, I am getting the following error message:
Microsoft Visual C++ Runtime Library
Runtime Error!
Program: c:Progr...
R6031
-Attempt to initialize the CRT more than once. This indicates a bug in your application
Need a solution.
Thanks a lot.
Read more
Hi guys.
I'm in need to get my newly acquired ULS PLS 4.60 Laser Engraver set up for some quick backlogged work.
I have found it assembled, exhausted, connected, and have the ULS driver and software loaded.
Everything seems in the right place, but I am receiving the below error message when I click on "Properties" in the print driver.
Need your help.
Thanks in advance
Error:
FireBird Error
invalid transaction handle (expecting
explicit transaction start) (initSelect start)
Read more
Hi experts,
Recently I have got a trouble with the latest windows home server update. It stops a number of users from renewing their connector software as well as reconnecting their computers to their abode server. When I am trying to attach back up people, I get a network error or cannot receive server message. Need to solve this error. Thanks in advance
Error:
Windows Home Server Connector
An error Occurred
This operation cannot be completed at this time.
Please try again later. If the problem persists, please contact Product Support.
Click here for more troubleshooting resources
Read more
I am using Internet Explorer 7 and decided to install its latest version which is the Internet Explorer 9 but every time I tried to run the installation, I always end up with an error with code 800F081e.
What can I do to fix it?
Read more
How can I create a password for my localhost? I can not find the exact way to do that.
Read more
I am trying to run Adobe Dreamweaver but it always show an error 0xc0000005. I called for a support and after spending many hours talking to a technical support, they told me that it is a problem with my Windows setting. Other Adobe programs works just fine except for this one. Can someone please help me on resolving this issue? Thanks.
Read more
When I try to open the Add or Remove Programs applet in the Control Panel, the following error message possibly will show: “Add or Remove Programs has been restricted”
Please help.
Thanks a lot.
Read more
I have two widgets which are coded in javascript and I wanted to use in same website but I don't know how to do it. Is it
possible to use two widget in the same website.If yes, please provide some suggestions. Thanks in advance.
Read more
I have troubles with sending files to the IGA. I am getting an error when I try to log in, receive or send files.The error codes recorded below are getting under the description group in the Outbox or Inbox section of the V1 Professional version 5.0 IGA window, or when trying to receive or send swing videos with the V1 Home or V1 Golf software. Need a solution.
Thanks in advance
Read more
Now, I want to use Linux as my operating system as I am fed up with my windows operating system. I would like to ask the
experts here ,who is also a web designer , that which software can replace Netbeans in Linux. Is there any alternative to it or I
will again have to come to windows platform to use it.
Read more
