Archive
I use windows XP and I want to burn a CD. Do I need any external software to burn a CD? Isn't there any built in program in
this operating system to burn CD? Any ideas experts?
Read more
I've been receiving a "cannot connect to server" notice whenever I try to log onto Google Talk using my BlackBerry.
Is anyone else encountering this error?
Read more
I wanted to run an exe file in DOS. Is it possible to run an exe file in DOS? If yes, how can I run this file? Please suggest
some ideas.
Read more
I was thinking that Windows server and Windows NT are same but now I have come to know that both are different.
That is why, I would like to ask the experts to tell me the difference and their applications about in which field and for what the purposes they are used?
Read more
I want some pictures in my website to fade in / fade out after certain interval but I can't figure out how to do this. I know that
with the help of Javascript, it can be done. But I wanted to learn some other easy way to do this. Any suggestions?
Read more
I want to make a bootable CD for my windows xp but I don't know how. Will you guys tell me how can I make my CD bootable?
Also, please help me with the best software for burning CD.
Read more
I have a file which I downloaded from internet and it has a extension of xml. Do you guys any idea about which software to
use to open the file?Please help me with this.
Read more
I am using Internet Download Manager to download data from internet but now it’s not working. I tried uninstalling and then reinstalling but still it is not able to connect to the internet to download the files. What may be the probable reason for this?
Read more
I use an old desktop PC and my PC configuration consists of 128 MB RAM, 80 GB hard disk, 1.83 GHz processor.
Will I be able to
Play Prince of Persia - The Two Thrones on it.
Please answer.
Read more
I have a mouse which works fine on my desktop pc but when I connect to my laptop, it does not work. What may be the problem?
Is there any problem with the driver of my laptop?
Read more
