Archive
When I try to delete the files on my recycle bin i get an error saying "Cannot delete desktop , the file or directory is corrupted or unreadable" I can delete them one by one but I can't delete them all at once, is there any way to solve this matter ? It would be a big help.
Thanks,
Read moreHi People,
I just arrived from work and i'm planning to upload my video presentation in my USB. I am using my desktop PC right now and I can't seem to find my files. I am pretty sure I copied it in my USB stick. Are my files deleted? Are they gone forever? If not, how can I get those back? I really need those files for work very badly.
Thank you. Glen Tapia
Read moreHi,
Please help me on my USB file it would not open. I try other USB it has no problem. In my laptop it wouldn't detect. For assistance please.
I'm just new on this site! My computer is showing a big problem that is when I want to remove any software from my computer then the computer is hanging and no respond until I switch off the computer. Please give a perfect solution for this problem.
Thanks,
Dave Goliath.
Read moreHere’s the background of the issue I am encountering. I am upgrading from Exchange 2003 server to Exchange 2010 server. The Exchange 2003 has SP2 Enterprise with 1 front end and 3 back-up end server and all functioning on Windows 2003 Standard SP2.One of our users in Outlook 2003 is scheduling an appointment with someone using Exchange 2010. He wants to view Exchange 2010 user’s calendar to check availability but he was unable to view it. All he sees are lines. He tried using OWA with the same results. However, users on Exchange 2010 can see each other’s calendars...
Read more
Hi All,
How to Rename File Extensions?
Thanks & Regards
Any help is of great use.
Cora Britain
A message ‘The application cannot be started. An internal error occurred’ popped up, and my OpenOffice.org 2.2 failed to initiate (The attached screenshot tells the story).
My operating system is Ubuntu 7.04 – Feisty Fawn. What can I do now?
Does the problem have anything to do with my operating system?
Please extend your helping hand.
OpenOffice.org 2.2
OK
Read moreWhile installing ‘SSW Link Auditor’ I faced the error message
Installer Information
Internal Error 2613.
As the message appeared, the installation process expired. I tried to install the application several times, but the result was the same ever time.
I want your help desperately to solve the issue.
Read more
An error message got me into trouble. It appears now and then on my monitor and I have no idea how to come up with a solution.
Please assist me in this case. I desperately need your help.
The message says, “Error Message ‘0x00000001’ referenced memory at ‘0x00000001’. The memory could not be ‘read’.” (Attached screenshot bears the details.)
avp.exe - Application Error
The instruction at "0x00000001" referenced memory at "0x00000001". The memory could not be "read".
Click on OK to terminate...
I installed ‘Document To Go’ in my PC and tried to open ‘Palm Desktop’.
But an error message popped up – ‘
Error: Exreprt.exe module cannot be found.
I don’t know how to solve the issue and decided to share it here.
I highly appreciate your suggestion concerning the issue.
Palm Desktop
Error: Expreprt.exe module cannot be found.
Read more
