Archive
I need to remove the ISP's DNS addresses clients and domain controller, I have multi IP addresses that run automatically added into DNS Simultaneously. If I remove it, will NAT be available to perform were NIC is disabled? In this case, is DHCP still under DC?
Read moreI have one DSL Modem and an internet connection on both computers. They are currently networked my computer that has the network adapter can get shared folders from my other computer. However, my computer can't get shared folders from my other computer. When I double click my other Router computer a windows explorer message pops up saying "Is not accessible". You might not have permission to us this network resource. Contact the administrator of this server to find out if you have access permissions. The Network path was not found.
I am having trouble with my disk space. I am not sure if it can still hold a file in my network computer. I am confused with the capacity. It seems like it is full, where all my files are not too large to feed the free space for almost three fourth of free space.
I decided to configure the problem, I tried to backup my files. It took two days, and it still keeps reading. It doesn't stop. What is the best option to back up my entire files?
Read moreSATA and SAS are quite compatible when it comes to pin where SATA drive can be used in serial SCSI.
Can I use SATA drive to iSCSI drive?
Can I use SATA or SAS in iSCSI? I need to know if I can optimize the access times and transfer rates and configure it for better performance.
If I change my current processor chip into a new one, a different model and a new version, and it is close relatively meets the specification of the motherboard, does my system net BIOS will change its settings as well as CMOS properties?
How about the other hardware will they be affected too?
Please give an answer regarding the matter.
I was trying to change back to legacy Grub, but after rebooting it thrice, it was encountering an error.
The screen just say "Grub is loading" or some other errors then it will restart. I was not even allowed to choose the OS I want. It locked me out of the system. I am now planning to remove Ubuntu entirely and just retain Windows Vista, but I don't want to regret it later, so now, I am asking for anyone's help on how I can do this without encountering the error. By the way, the reason I'm trying to do...
Read moreHi!
I would just check here since I guess its not exactly normal.
The only problem I've been having lately is that this Message always appear.
My terminal server can locate the license server and DNS is okay on each computer.
I Have tried several times, I pinged the IP address and it run.
But my remote computer is still disconnected.
I used .netPROTECT 2.2 and my operating system is windows Vista.
Is the .netPROTECT 2.2 Windows Server affecting my licensing protocol?
I have a problem with my Operating System administrator, My Operating System is Windows 7. I don't know to disable my administrator. I cant stall freely.
I hope someone could help me with it.
Many thanks.
I have a wireless network, and I have used Proprietary USB Modem, my OS is Windows XP.
I host websites using this IP address 192.168.0.2 and I noticed that there are lots of spam e-mail.
What IP address fits with my network connection?
What can I use here?
Please help.
Read more
